Here is the automation I wrote before assist timers and it still works. When the timer is finished I get a notification on my phone and smart speaker. The “time left” part required 2 sensors as when created by using the timer helper it doesn’t really have a time left attribute. I did this completely through the GUI automation tool, using the sentence/response method. I created 2 helpers, only one is utilizes hours as most timers are under an hour that I set. Below is just minutes and seconds but easy to change for hours.
alias: responce_timer_test
description: ""
- platform: conversation
command:
- (Set|start|begin) (a|an) {minutes} minute timer
- (Set|start|begin) a timer for {minutes} minutes
- "{minutes} minute timer"
command:
- (Set|start|begin) a timer for {minutes} minutes (and) {seconds} seconds
- (Set|start|begin) a {minutes} minute (and) {seconds} second timer
- "{minutes} minute (and) {seconds} second timer"
id: Timer minutes and seconds
command:
- (Set|start|begin) a timer (for|with) {seconds} seconds
- (Set|start|begin) a {seconds} second timer
id: Timer seconds only
command: (cancel|stop) timer
command: Pause timer
id: "Pause timer "
command:
- "Resume timer "
id: "Resume timer "
command:
- Time remaining
- time left
- how much longer
id: Time Remaining
- platform: state
entity_id:
- timer.test_timer
to: idle
condition: []
- choose:
- conditions:
- condition: trigger
id:
- Start Timer
sequence:
- target:
entity_id: timer.test_timer
duration: 00:0{{ trigger.slots.minutes }}:00{{ trigger.slots.seconds }}
enabled: true
action: timer.start
- set_conversation_response: "timer set for {{ trigger.slots.minutes }} minutes "
enabled: true
- conditions:
id:
- Timer minutes and seconds
sequence:
- target:
enabled: true
action: timer.start
- set_conversation_response: >-
timer set for {{ trigger.slots.minutes }} minutes and
{{trigger.slots.seconds }} seconds
enabled: true
- conditions:
id:
- Timer seconds only
sequence:
- target:
enabled: true
action: timer.start
- set_conversation_response: timer set for {{ trigger.slots.seconds }} seconds
enabled: true
- conditions:
id:
- Pause timer
sequence:
- target:
data: {}
action: timer.pause
- conditions:
id:
- Cancel Timer
sequence:
- data: {}
action: timer.cancel
- conditions:
id:
- "Resume timer "
sequence:
- target:
data: {}
action: timer.start
- conditions:
id:
- Time Remaining
sequence:
- metadata: {}
data: {}
action: timer.pause
enabled: true
- metadata: {}
data: {}
action: timer.start
enabled: true
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 300
There is {% if is_state('timer.test_timer', 'active') %} {{
states('sensor.timer_display') }} {% else %} no timer set or
remaining {% endif %}
enabled: true
- set_conversation_response: |-
There is
{% set f = state_attr('timer.test_timer', 'finishes_at') %}
{{ '00:00:00' if f == None else
(as_datetime(f) - now()).total_seconds() | timestamp_custom('%H:%M:%S', false) }} remaining
enabled: false
- conditions:
id:
- Timer end
sequence:
- data:
entity_id: media_player.sound_bar
message: >-
(the timer finished at {{ now().strftime('%-I') }} {{
now().strftime('%M %p') }} on {{ now().strftime('%A') }} {{
now().strftime('%B') }} {{ now().strftime('%d') }}
cache: true
enabled: true
action: tts.cloud_say
- metadata: {}
title: "TIMER DONE!!! "
message: >-
The timer finished at {{ now().strftime('%-I') }} {{
{{ now().strftime('%B') }} {{ now().strftime('%d') }}
action: notify.mobile_app_pixel_8a
- data:
entity_id: media_player.vlc_telnet
message: >-
cache: true
enabled: true
mode: single
