I use Alexa to set countdown timers for things in the oven. It would be great if I could ask Assist to do this instead. Is this already possible via some sort of integration?
I’m doing some coding to get this to work. To summarize, I created 3 timers (I barely use multiple timers, so 3 is enough for me) that assist can control; start, stop and ask the remaining time on one or all timers at once. I think my script could be more efficient and cleaner, but it works. I’m working on pausing a timer now. The responses are also written in Dutch, but translating wouldn’t be that much work.
Are you willing to share your script, @DonNL?
If you wouldn’t mind sharing the scripts, that would be great.
Sure. Again it’s probably not the most efficient way of handling it, but it works so far.
config_assist_intent_script.yaml
TimerStart:
speech:
text: >
{{ (["Geen probleem. ", "Goed. ", "Natuurlijk. ", ""] | random) + (["Ik start de timer voor ", "Timer gestart voor ", "Ik zet een timer voor ", "Timer geactiveerd voor "] | random)}}{% if (hours | int(default=0)) == 1 %}{{ (hours | int)}} uur{% elif (hours | int(default=0)) > 1 %}{{ (hours | int)}} uren{% endif %}{% if (hours | int(default=0)) > 0 and ((minutes | int(default=0)) > 0 or (seconds | int(default=0)) > 0) %} en {% endif %}{% if (minutes | int(default=0)) == 1 %}{{ (minutes | int)}} minuut{% elif (minutes | int(default=0)) > 1 %}{{ (minutes | int)}} minuten{% endif %}{% if (minutes | int(default=0)) > 0 and (seconds | int(default=0)) > 0 %} en {% endif %}{% if (seconds | int(default=0)) == 1 %}{{ (seconds | int)}} seconde{% elif (seconds | int(default=0)) > 1 %}{{ (seconds | int)}} seconden{% endif %}.
service: script.start_timer
data_template:
duration: "{{hours | int(default=0)}}:{{ minutes | int(default=0) }}:{{ seconds | int(default=0) }}"
entity_id: >
{% if states('timer.timer1') != 'active' and states('timer.timer1') != 'paused' %} timer.timer1
{% elif states('timer.timer2') != 'active' and states('timer.timer2') != 'paused' %} timer.timer2
{% else %} timer.timer3{% endif%}
TimerStop:
speech:
text: >
{% if states.timer|selectattr('state','eq','active')|list|length == 0 %}
Er zijn momenteel geen timers actief.
{% elif (states.timer|selectattr('state','eq','active')|list|length -1 == 1) or (timer != 'timer.timer0') and states(timer) == 'active'%}
{{ (["Akkoord. ", "Begrepen. ", "Goed. ", ""] | random) }}{{ (["Geannuleerd.", "Timer geannuleerd.", "Gestopt.", "Timer gestopt.", "Gedeactiveerd.", "Timer gedeactiveerd.", "Timer uitgeschakeld.", "Uitgeschakeld."] | random) }}
{% elif (states.timer|selectattr('state','eq','active')|list|length > 1) and (timer == 'timer.timer1, timer.timer2, timer.timer3') %}
{{ (["Akkoord. ", "Begrepen. ", "Goed. ", ""] | random) }}{{ (["Geannuleerd.", "Alle timers geannuleerd.", "Gestopt.", "Alle timers gestopt.", "Gedeactiveerd.", "Alle timers gedeactiveerd.", "Alle timers uitgeschakeld.", "Uitgeschakeld."] | random) }}
{% else %}{% if states(timer) != 'active' %}Deze timer is momenteel niet actief. {% endif %}{% if states.timer|selectattr('state','eq','active')|list|length == 2 %}Er is momenteel {{ states.timer|selectattr('state','eq','active')|list|length - 1}} timer actief. {%
else %}Er zijn momenteel {{ states.timer|selectattr('state','eq','active')|list|length - 1}} timers actief. {% endif %}{%
if states.timer.timer1.state == 'active' %}{%
set duration = "" %}{%
if states.timer.timer1.attributes.duration[:2] | int(default=0) > 9 %}{%
set hr = states.timer.timer1.attributes.duration[:2] %}{% else %}{%
set hr = states.timer.timer1.attributes.duration[:1] %}{% endif %}{%
if states.timer.timer1.attributes.duration[3:][:2] | int(default=0) > 9 %}{%
set min = states.timer.timer1.attributes.duration[3:][:2] %}{% else %}{%
set min = states.timer.timer1.attributes.duration[3:][:1] %}{% endif %}{%
if states.timer.timer1.attributes.duration[5:] | int(default=0) > 9 %}{%
set sec = states.timer.timer1.attributes.duration[5:] %}{% else %}{%
set sec = states.timer.timer1.attributes.duration[6:] %}{% endif %}{%
if hr | int(default=0) > 0 %}{% set duration = duration + hr + " uur " %}{% endif %}{%
if min | int(default=0) == 1 %}{% set duration = duration + min + " minuut " %}{%
elif min | int(default=0) > 1 %}{% set duration = duration + min + " minuten " %}{% endif %}{%
if sec | int(default=0) == 1 %}{% set duration = duration + sec + " seconde " %}{%
elif sec | int(default=0) > 1 %}{% set duration = duration + sec + " seconden " %}{% endif %}De {%
if (states.timer|selectattr('state','eq','active')|list|length - 1) != 1%}eerste {% endif %}timer van {{ duration }}is actief met nog {%
if (states['timer.timer1'].attributes.duration != "none") or (states['timer.timer1'].state == "active") -%}{%
if (as_datetime(state_attr('timer.timer1', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%H', false) | int > 0 %}{{ (as_datetime(state_attr('timer.timer1', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%H', false) | int }} uur {% endif %}{%
if (as_datetime(state_attr('timer.timer1', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%M', false) | int == 1 %} 1 minuut{%
elif (as_datetime(state_attr('timer.timer1', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%M', false) | int > 1 %}{{ (as_datetime(state_attr('timer.timer1', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%M', false) | int }} minuten {% endif %}{%
if (as_datetime(state_attr('timer.timer1', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%H', false) | int > 0 %}{%
elif (as_datetime(state_attr('timer.timer1', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%S', false) | int == 1 %} 1 seconde{%
elif (as_datetime(state_attr('timer.timer1', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%S', false) | int > 1 %}{{ (as_datetime(state_attr('timer.timer1', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%S', false) | int }} seconden {% endif %}{% endif %}te gaan. {%
endif %}{%
if states.timer.timer2.state == 'active' %}{%
if states.timer.timer2.attributes.duration[:2] | int(default=0) > 9 %}{%
set hr = states.timer.timer2.attributes.duration[:2] %}{% else %}{%
set hr = states.timer.timer2.attributes.duration[:1] %}{% endif %}{%
if states.timer.timer2.attributes.duration[3:][:2] | int(default=0) > 9 %}{%
set min = states.timer.timer2.attributes.duration[3:][:2] %}{% else %}{%
set min = states.timer.timer2.attributes.duration[3:][:1] %}{% endif %}{%
if states.timer.timer2.attributes.duration[5:] | int(default=0) > 9 %}{%
set sec = states.timer.timer2.attributes.duration[5:] %}{% else %}{%
set sec = states.timer.timer2.attributes.duration[6:] %}{% endif %}{%
if sec | int(default=0) == 1 and hr | int(default=0) == 0 %}{% set duration = duration + sec + " seconde " %}{%
elif sec | int(default=0) > 1 and hr | int(default=0) == 0 %}{% set duration = duration + sec + " seconden " %}{% endif %}De {%
if (states.timer|selectattr('state','eq','active')|list|length - 1) != 1%}tweede {% endif %}timer van {{ duration }}is actief met nog {%
if (states['timer.timer2'].attributes.duration != "none") or (states['timer.timer2'].state == "active") -%}{%
if (as_datetime(state_attr('timer.timer2', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%H', false) | int > 0 %}{{ (as_datetime(state_attr('timer.timer2', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%H', false) | int }} uur {% endif %}{%
if (as_datetime(state_attr('timer.timer2', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%M', false) | int == 1 %} 1 minuut{%
elif (as_datetime(state_attr('timer.timer2', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%M', false) | int > 1 %}{{ (as_datetime(state_attr('timer.timer2', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%M', false) | int }} minuten {% endif %}{%
if (as_datetime(state_attr('timer.timer2', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%H', false) | int > 0 %}{%
elif (as_datetime(state_attr('timer.timer2', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%S', false) | int == 1 %} 1 seconde{%
elif (as_datetime(state_attr('timer.timer2', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%S', false) | int > 1 %}{{ (as_datetime(state_attr('timer.timer2', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%S', false) | int }} seconden {% endif %}{% endif %}te gaan. {%
endif %}{%
if states.timer.timer3.state == 'active' %}{%
if states.timer.timer3.attributes.duration[:2] | int(default=0) > 9 %}{%
set hr = states.timer.timer3.attributes.duration[:2] %}{% else %}{%
set hr = states.timer.timer3.attributes.duration[:1] %}{% endif %}{%
if states.timer.timer3.attributes.duration[3:][:2] | int(default=0) > 9 %}{%
set min = states.timer.timer3.attributes.duration[3:][:2] %}{% else %}{%
set min = states.timer.timer3.attributes.duration[3:][:1] %}{% endif %}{%
if states.timer.timer3.attributes.duration[5:] | int(default=0) > 9 %}{%
set sec = states.timer.timer3.attributes.duration[5:] %}{% else %}{%
set sec = states.timer.timer3.attributes.duration[6:] %}{% endif %}{%
if (states.timer|selectattr('state','eq','active')|list|length - 1) != 1%}derde {% endif %}timer van {{ duration }}is actief met nog {%
if (states['timer.timer3'].attributes.duration != "none") or (states['timer.timer3'].state == "active") -%}{%
if (as_datetime(state_attr('timer.timer3', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%H', false) | int > 0 %}{{ (as_datetime(state_attr('timer.timer3', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%H', false) | int }} uur {% endif %}{%
if (as_datetime(state_attr('timer.timer3', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%M', false) | int == 1 %} 1 minuut{%
elif (as_datetime(state_attr('timer.timer3', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%M', false) | int > 1 %}{{ (as_datetime(state_attr('timer.timer3', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%M', false) | int }} minuten {% endif %}{%
if (as_datetime(state_attr('timer.timer3', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%H', false) | int > 0 %}{%
elif (as_datetime(state_attr('timer.timer3', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%S', false) | int == 1 %} 1 seconde{%
elif (as_datetime(state_attr('timer.timer3', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%S', false) | int > 1 %}{{ (as_datetime(state_attr('timer.timer3', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%S', false) | int }} seconden {% endif %}{% endif %}te gaan. {%
endif %}{{ (["Specificeer alstublieft welke timer u wilt stoppen.", "Geef alstublieft aan welke timer u wilt stoppen.", "Benoem alstublieft welke timer u wilt stoppen.", ""] | random) }}{% endif %}
service: script.stop_timer
data_template:
entity_id: "{{ timer }}"
TimerDuration:
speech:
text: >
{% else %}{% if states.timer|selectattr('state','eq','active')|list|length == 2 and timer == 'timer.timer0' %}Er is momenteel {{ states.timer|selectattr('state','eq','active')|list|length - 1}} timer actief. {%
elif timer == 'timer.timer0' %}
if states.timer.timer1.state == 'active' and (timer == 'timer.timer1' or timer == 'timer.timer0') %}{%
elif sec | int(default=0) > 1 %}{% set duration = duration + sec + " seconden " %}{% endif %}De eerste timer van {{ duration }}is actief met nog {%
endif %}{%
if states.timer.timer2.state == 'active' and (timer == 'timer.timer2' or timer == 'timer.timer0') %}{%
elif sec | int(default=0) > 1 %}{% set duration = duration + sec + " seconden " %}{% endif %}De tweede timer van {{ duration }}is actief met nog {%
endif %}{%
if states.timer.timer3.state == 'active' and (timer == 'timer.timer3' or timer == 'timer.timer0') %}{%
elif sec | int(default=0) > 1 %}{% set duration = duration + sec + " seconden " %}{% endif %}De derde timer van {{ duration }}is actief met nog {%
endif %}{% endif %}
custom_sentences/nl/timer_start.yaml
language: "nl"
intents:
TimerStart:
#Alle tijden
- sentences:
- "(start|zet|<zou>) [een] timer (voor|van) {hours} (uur|uren) [en] {minutes} (minuut|minuten) [en] {seconds} (seconde|seconden) [[willen|kunnen] <doe>] [starten]"
#Alleen uur
- sentences:
- "(start|zet|<zou>) [een] timer (voor|van) {hours} (uur|uren) [[willen|kunnen] <doe>] [starten]"
slots:
seconds: 0
minutes: 0
#Alleen minuut
- sentences:
- "(start|zet|<zou>) [een] timer (voor|van) {minutes} (minuut|minuten) [[willen|kunnen] <doe>] [starten]"
slots:
seconds: 0
hours: 0
#Alleen seconde
- sentences:
- "(start|zet|<zou>) [een] timer (voor|van) {seconds} (seconde|seconden) [[willen|kunnen] <doe>] [starten]"
slots:
minutes: 0
hours: 0
#Geen uur, wel minuten en seconden
- sentences:
- "(start|zet|<zou>) [een] timer (voor|van) {minutes} (minuut|minuten) [en] {seconds} (seconde|seconden) [[willen|kunnen] <doe>] [starten]"
slots:
hours: 0
#Geen seconden, wel uren en minuten
- sentences:
- "(start|zet|<zou>) [een] timer (voor|van) {hours} (uur|uren) [en] {minutes} (minuut|minuten) [[willen|kunnen] <doe>] [starten]"
slots:
seconds: 0
#Halven
- sentences:
- "(start|zet|<zou>) [een] timer (voor|van) [{minutes}][ ]([en] [een] half | [en] [een] halve) minuut [[willen|kunnen] <doe>] [starten]"
- "(start|zet|<zou>) [een] timer (voor|van) (0,5|0.5) minuut [[willen|kunnen] <doe>] [starten]"
slots:
hours: 0
seconds: 30
- sentences:
- "(start|zet|<zou>) [een] timer (voor|van) (anderhalve|anderhalf) minuut [[willen|kunnen] <doe>] [starten]"
- "(start|zet|<zou>) [een] timer (voor|van) (1,5|1.5) minuut [[willen|kunnen] <doe>] [starten]"
slots:
hours: 0
seconds: 30
minutes: 1
- sentences:
- "(start|zet|<zou>) [een] timer (voor|van) [{hours}][ ]([en] [een] half | [en] [een] halve) uur [[willen|kunnen] <doe>] [starten]"
slots:
minutes: 30
seconds: 0
- sentences:
- "(start|zet|<zou>) [een] timer (voor|van) (anderhalve|anderhalf) uur [[willen|kunnen] <doe>] [starten]"
- "(start|zet|<zou>) [een] timer (voor|van) (1,5|1.5) uur [[willen|kunnen] <doe>] [starten]"
slots:
hours: 1
seconds: 0
minutes: 30
lists:
seconds:
range:
to: 120
minutes:
range:
to: 120
hours:
range:
to: 24
custom_sentences/nl/timer_stop.yaml
language: "nl"
intents:
TimerStop:
- sentences:
- "(stop|annuleer|<zou>) [de] {timer} timer[s] [[willen|kunnen] <doe>] [stoppen|annuleren|uitzetten]"
- sentences:
- "(stop|annuleer|<zou>) [de] timer [[willen|kunnen] <doe>] [stoppen|annuleren|uitzetten]"
slots:
timer: "timer.timer0"
lists:
timer:
values:
- in: "eerste"
out: "timer.timer1"
- in: "tweede"
out: "timer.timer2"
- in: "derde"
out: "timer.timer3"
- in: "alle"
out: "timer.timer1, timer.timer2, timer.timer3"
custom_sentences/nl/timer_duration.yaml
language: "nl"
intents:
TimerDuration:
- sentences:
- "(hoe lang|hoeveel tijd) nog op de {timer} timer"
- "hoe lang duurt de {timer} timer nog"
- sentences:
- "(hoe lang|hoeveel tijd) nog op de timer[s]"
- "hoe lang [duurt|duren] de timer[s] nog"
slots:
lists:
timer:
values:
- in: "eerste"
out: "timer.timer1"
- in: "tweede"
out: "timer.timer2"
- in: "derde"
out: "timer.timer3"
- in: "alle"
scripts.yaml
start_timer:
alias: Start Timer
mode: single
sequence:
- service: timer.start
data_template:
duration: "{{ duration }}"
entity_id: >
timer.timer1
timer.timer2
{% else %}
timer.timer3
{% endif%}
entity_id: >
input_boolean.timer1_actief
input_boolean.timer2_actief
{% else %}
input_boolean.timer3_actief
{% endif%}
stop_timer:
alias: Stop Timer
mode: single
sequence:
- choose:
- conditions:
- condition: template
value_template: "{{ (states.timer|selectattr('state','eq','active')|list|length > 2 and entity_id != 'timer.timer0') or (states.timer|selectattr('state','eq','active')|list|length == 2 and entity_id == 'timer.timer0') or (entity_id == 'timer.timer1, timer.timer2, timer.timer3') }}"
value_template: "{{ states(entity_id) == 'active' or entity_id == 'timer.timer1, timer.timer2, timer.timer3' }}"
sequence:
- service: input_boolean.turn_off
entity_id: >
{% if entity_id == 'timer.timer1, timer.timer2, timer.timer3' %}
input_boolean.timer1_actief, input_boolean.timer2_actief, input_boolean.timer3_actief
{% elif states(entity_id) == 'active' and entity_id != 'timer.timer0'%}
{{ "input_boolean." + entity_id[6:] + "_actief"}}
{% else %}
{% endif %}
default:
- service: script.nothing
Thanks so much for this!
I’ve tried my best to configure it, but I suspect perhaps something has been lost in translation as I get this error:
File “/usr/src/homeassistant/homeassistant/components/assist_pipeline/pipeline.py”, line 518, in recognize_intent
conversation_result = await conversation.async_converse(
File “/usr/src/homeassistant/homeassistant/components/conversation/init.py”, line 373, in async_converse
result = await agent.async_process(
File “/usr/src/homeassistant/homeassistant/components/conversation/default_agent.py”, line 177, in async_process
result = await self.hass.async_add_executor_job(
File “/usr/local/lib/python3.10/concurrent/futures/thread.py”, line 58, in run
File “/usr/src/homeassistant/homeassistant/components/conversation/default_agent.py”, line 252, in _recognize
for result in recognize_all(
File “/usr/local/lib/python3.10/site-packages/hassil/recognize.py”, line 258, in recognize_all
for maybe_match_context in maybe_match_contexts:
File “/usr/local/lib/python3.10/site-packages/hassil/recognize.py”, line 500, in match_expression
group_contexts = [
group_contexts = [
File “/usr/local/lib/python3.10/site-packages/hassil/recognize.py”, line 492, in match_expression
yield from match_expression(settings, context, item)
group_contexts = [
File “/usr/local/lib/python3.10/site-packages/hassil/recognize.py”, line 500, in <listcomp>
group_contexts = [
File “/usr/local/lib/python3.10/site-packages/hassil/recognize.py”, line 615, in match_expression
raise MissingRuleError(f"Missing expansion rule <{rule_ref.rule_name}>")
hassil.recognize.MissingRuleError: Missing expansion rule <would>
I suspect somewhere in translation I’ve missed something up, especially around perhaps the meaning of “would”. :-/
This is what my configurations look like:
configuration.yaml
intent_script: !include config_assist_intent_script.yaml
TimerStart:
speech:
text: >
{{ (["No problem. ", "Good. ", "Of course. ", ""] | random) + (["I'll start the timer for ", "Timer started for ", "I'll set a timer for ", "Timer activated for "] | random)}}{% if (hours | int(default=0)) == 1 %}{{ (hours | int)}} hour{% elif (hours | int(default=0)) > 1 %}{{ (hours | int)}} hours{% endif %}{% if (hours | int(default=0)) > 0 and ((minutes | int(default=0)) > 0 or (seconds | int(default=0)) > 0) %} en {% endif %}{% if (minutes | int(default=0)) == 1 %}{{ (minutes | int)}} minute{% elif (minutes | int(default=0)) > 1 %}{{ (minutes | int)}} minutes{% endif %}{% if (minutes | int(default=0)) > 0 and (seconds | int(default=0)) > 0 %} en {% endif %}{% if (seconds | int(default=0)) == 1 %}{{ (seconds | int)}} second{% elif (seconds | int(default=0)) > 1 %}{{ (seconds | int)}} seconds{% endif %}.
service: script.voice_start_timer
data_template:
entity_id: >
TimerStop:
speech:
text: >
There are currently no timers active.
{{ (["Agreement. ", "Understood. ", "Good. ", ""] | random) }}{{ (["Cancelled.", "Timer cancelled.", "Stopped.", "Timer stopped.", "Deactivated.", "Timer deactivated.", "Timer disabled.", "Disabled."] | random) }}
{{ (["Agreement. ", "Understood. ", "Good. ", ""] | random) }}{{ (["Cancelled.", "All timers cancelled.", "Stopped.", "All timers stopped.", "Deactivated.", "All timers deactivated.", "All timers disabled.", "Disabled."] | random) }}
{% else %}{% if states(timer) != 'active' %}This timer is currently not active. {% endif %}{% if states.timer|selectattr('state','eq','active')|list|length == 2 %}There is currently {{ states.timer|selectattr('state','eq','active')|list|length - 1}} timer active. {%
else %}There are currently {{ states.timer|selectattr('state','eq','active')|list|length - 1}} timers active. {% endif %}{%
if hr | int(default=0) > 0 %}{% set duration = duration + hr + " hour " %}{% endif %}{%
if min | int(default=0) == 1 %}{% set duration = duration + min + " minute " %}{%
elif min | int(default=0) > 1 %}{% set duration = duration + min + " minutes " %}{% endif %}{%
if sec | int(default=0) == 1 %}{% set duration = duration + sec + " second " %}{%
elif sec | int(default=0) > 1 %}{% set duration = duration + sec + " seconds " %}{% endif %}The {%
if (states.timer|selectattr('state','eq','active')|list|length - 1) != 1%}first {% endif %}timer of {{ duration }}is active with still {%
if (as_datetime(state_attr('timer.timer1', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%H', false) | int > 0 %}{{ (as_datetime(state_attr('timer.timer1', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%H', false) | int }} hour {% endif %}{%
if (as_datetime(state_attr('timer.timer1', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%M', false) | int == 1 %} 1 minute{%
elif (as_datetime(state_attr('timer.timer1', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%M', false) | int > 1 %}{{ (as_datetime(state_attr('timer.timer1', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%M', false) | int }} minutes {% endif %}{%
elif (as_datetime(state_attr('timer.timer1', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%S', false) | int == 1 %} 1 second{%
elif (as_datetime(state_attr('timer.timer1', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%S', false) | int > 1 %}{{ (as_datetime(state_attr('timer.timer1', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%S', false) | int }} seconds {% endif %}{% endif %}to go. {%
endif %}{%
if sec | int(default=0) == 1 and hr | int(default=0) == 0 %}{% set duration = duration + sec + " second " %}{%
elif sec | int(default=0) > 1 and hr | int(default=0) == 0 %}{% set duration = duration + sec + " seconds " %}{% endif %}De {%
if (states.timer|selectattr('state','eq','active')|list|length - 1) != 1%}second {% endif %}timer van {{ duration }}is active with still {%
if (as_datetime(state_attr('timer.timer2', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%H', false) | int > 0 %}{{ (as_datetime(state_attr('timer.timer2', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%H', false) | int }} hour {% endif %}{%
if (as_datetime(state_attr('timer.timer2', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%M', false) | int == 1 %} 1 minute{%
elif (as_datetime(state_attr('timer.timer2', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%M', false) | int > 1 %}{{ (as_datetime(state_attr('timer.timer2', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%M', false) | int }} minutes {% endif %}{%
elif (as_datetime(state_attr('timer.timer2', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%S', false) | int == 1 %} 1 second{%
elif (as_datetime(state_attr('timer.timer2', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%S', false) | int > 1 %}{{ (as_datetime(state_attr('timer.timer2', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%S', false) | int }} seconds {% endif %}{% endif %}to go. {%
endif %}{%
elif sec | int(default=0) > 1 %}{% set duration = duration + sec + " seconds " %}{% endif %}De {%
if (states.timer|selectattr('state','eq','active')|list|length - 1) != 1%}derde {% endif %}timer of {{ duration }}is active with still {%
if (as_datetime(state_attr('timer.timer3', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%H', false) | int > 0 %}{{ (as_datetime(state_attr('timer.timer3', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%H', false) | int }} hour {% endif %}{%
if (as_datetime(state_attr('timer.timer3', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%M', false) | int == 1 %} 1 minute{%
elif (as_datetime(state_attr('timer.timer3', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%M', false) | int > 1 %}{{ (as_datetime(state_attr('timer.timer3', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%M', false) | int }} minutes {% endif %}{%
elif (as_datetime(state_attr('timer.timer3', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%S', false) | int == 1 %} 1 second{%
elif (as_datetime(state_attr('timer.timer3', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%S', false) | int > 1 %}{{ (as_datetime(state_attr('timer.timer3', 'finishes_at')) - now()).total_seconds() | timestamp_custom('%S', false) | int }} seconds {% endif %}{% endif %}to go. {%
endif %}{{ (["Please specify which timer you want to stop.", "Please tell me which timer you want to stop.", "Please name which timer you want to stop.", ""] | random) }}{% endif %}
service: script.voice_stop_timer
data_template:
TimerDuration:
speech:
text: >
{% else %}{% if states.timer|selectattr('state','eq','active')|list|length == 2 and timer == 'timer.timer0' %}There is currently {{ states.timer|selectattr('state','eq','active')|list|length - 1}} timer active. {%
elif sec | int(default=0) > 1 %}{% set duration = duration + sec + " seconds " %}{% endif %}The first timer of {{ duration }}is active with still {%
endif %}{%
elif sec | int(default=0) > 1 %}{% set duration = duration + sec + " seconds " %}{% endif %}The second timer of {{ duration }}is active with still {%
endif %}{%
elif sec | int(default=0) > 1 %}{% set duration = duration + sec + " seconds " %}{% endif %}The third timer of {{ duration }}is active with still {%
endif %}{% endif %}
custom_sentences/en/timer_start.yaml
language: "en"
intents:
TimerStart:
#All times
- sentences:
- "(start|set|<would>) [a] timer (for|from) {hours} (hour|hours) [and] {minutes} (minute|minutes) [and] {seconds} (second|seconds) [[want|can] <do>] [start]"
#All one hour
- sentences:
- "(start|set|<would>) [a] timer (for|from) {hours} (hour|hours) [[want|can] <do>] [start]"
slots:
seconds: 0
minutes: 0
#All one minute
- sentences:
- "(start|set|<would>) [a] timer (for|from) {minutes} (minute|minutes) [[want|can] <do>] [start]"
slots:
seconds: 0
hours: 0
#All one second
- sentences:
- "(start|set|<would>) [a] timer (for|from) {seconds} (second|seconds) [[want|can] <do>] [start]"
slots:
minutes: 0
hours: 0
#Gone hour, wel minutes and seconds
- sentences:
- "(start|set|<would>) [a] timer (for|from) {minutes} (minute|minutes) [en] {seconds} (second|seconds) [[want|can] <do>] [start]"
slots:
hours: 0
#Gone seconds, wel hours and minutes
- sentences:
- "(start|set|<would>) [a] timer (for|from) {hours} (hour|hours) [en] {minutes} (minute|minutes) [[want|can] <do>] [start]"
slots:
seconds: 0
#Halven
- sentences:
- "(start|set|<would>) [a] timer (for|from) [{minutes}][ ]([en] [one] half | [en] [one] halve) minute [[want|can] <do>] [start]"
- "(start|set|<would>) [a] timer (for|from) (0,5|0.5) minute [[want|can] <do>] [start]"
slots:
hours: 0
seconds: 30
- sentences:
- "(start|set|<would>) [a] timer (for|from) (anderhalve|anderhalf) minute [[want|can] <do>] [start]"
- "(start|set|<would>) [a] timer (for|from) (1,5|1.5) minute [[want|can] <do>] [start]"
slots:
hours: 0
seconds: 30
minutes: 1
- sentences:
- "(start|move|<would>) [a] timer (for|from) [{hours}][ ]([en] [one] half | [en] [one] halve) hour [[want|can] <do>] [start]"
slots:
minutes: 30
seconds: 0
- sentences:
- "(start|move|<would>) [a] timer (for|from) (anderhalve|anderhalf) hour [[want|can] <do>] [start]"
- "(start|move|<would>) [a] timer (for|from) (1,5|1.5) hour [[want|can] <do>] [start]"
slots:
hours: 1
seconds: 0
minutes: 30
lists:
seconds:
range:
to: 120
minutes:
range:
to: 120
hours:
range:
to: 24
custom_sentences/en/timer_stop.yaml
language: "en"
intents:
TimerStop:
- sentences:
- "(stop|cancel|<would>) [the] {timer} timer[s] [[want|can] <do>] [stop|annul|turn off]"
- sentences:
- "(stop|cancel|<would>) [the] timer [[want|can] <do>] [stop|annul|turn off]"
slots:
lists:
timer:
values:
- in: "first"
out: "timer.timer1"
- in: "second"
out: "timer.timer2"
- in: "third"
out: "timer.timer3"
- in: "all"
custom_sentences/en/timer_duration.yaml
language: "en"
intents:
TimerDuration:
- sentences:
- "(how long|how much time) still on the {timer} timer"
- "how long does the {timer} timer still"
- sentences:
- "(how long|how much time) still on the timer[s]"
- "how long [takes|last] the timer[s] still"
slots:
lists:
timer:
values:
- in: "first"
out: "timer.timer1"
- in: "second"
out: "timer.timer2"
- in: "third"
out: "timer.timer3"
- in: "all"
scripts.yaml
voice_start_timer:
alias: VOICE - Start timer
sequence:
data_template:
duration: '{{ duration }}'
entity_id: '{% if states(''timer.timer1'') != ''active'' and states(''timer.timer1'')
!= ''paused'' %} timer.timer1 {% elif states(''timer.timer2'') != ''active''
and states(''timer.timer2'') != ''paused'' %} timer.timer2 {% else %} timer.timer3
{% endif%}
!= ''paused'' %} input_boolean.timer1_actief {% elif states(''timer.timer2'')
!= ''active'' and states(''timer.timer2'') != ''paused'' %} input_boolean.timer2_active
{% else %} input_boolean.timer3_active {% endif%}
mode: single
voice_stop_timer:
alias: VOICE - Stop timer
sequence:
- choose:
- conditions:
value_template: '{{ (states.timer|selectattr(''state'',''eq'',''active'')|list|length
> 2 and entity_id != ''timer.timer0'') or (states.timer|selectattr(''state'',''eq'',''active'')|list|length
== 2 and entity_id == ''timer.timer0'') or (entity_id == ''timer.timer1,
timer.timer2, timer.timer3'') }}'
value_template: '{{ states(entity_id) == ''active'' or entity_id == ''timer.timer1,
timer.timer2, timer.timer3'' }}'
sequence:
entity_id: '{% if entity_id == ''timer.timer1, timer.timer2, timer.timer3''
%} input_boolean.timer1_active, input_boolean.timer2_active, input_boolean.timer3_active
{% elif states(entity_id) == ''active'' and entity_id != ''timer.timer0''%}
{{ "input_boolean." + entity_id[6:] + "_active"}} {% else %} input_boolean.timer1_active,
input_boolean.timer2_active, input_boolean.timer3_active {% endif %}
default:
mode: single
The Dutch intents have “zou” in its “library” with several options pre-figured. I think the error is that would doesnt have that. Remove the <>.
So it’s:
(start|set|would) …
Does that help?
That’s progress, now getting this at least:
I think I might play with the structure of the sentences a bit, as I’m not sure if the [start] is required?
Can you show the log output again?
And these [ ] brackets mean the word is optional in a sentence
Maybe try this:
- "[could|would] [you] (start|set) [a] timer (for|from|of) {minutes} (minute|minutes)"
Oddly enough, I’ve made it incredibly specific (as we have been trained using Alexa for years, so always set a timer with the same command), and still get the same error:
I wonder if I’m missing something else?
Hmm… then im not sure. Where did you place the files? What folders?
I got this working, thanks @DonNL & thanks @DeLorean for the translation work. When I ask how long is left on my timer, it tells me I have 0 timers active but then proceeds to tell me the time left on the timer. Weird bug, I’ll try to look into it.
Did you actually get it working via voice?
I still wasn’t able to get it to do anything.
Yes, it work with voice (apart from bug mentioned) you need to manually create the timers themselves (In helpers) you obviously need an automation for when the timer expires. I had a few problems with it not finding the scripts and Had to recreate them.
Since this was my first play with voice, I created a very simple intent where I say ‘test’ and I get phone notification confirming. That helped me understand how it all works.
Any chance you can share your intents and intent scripts please?
I’ll see if they work for me, as mine didn’t.
contents of /config/config_assist_intent_script.yaml
TimerStart:
speech:
text: >
service: script.1689339465689
data_template:
entity_id: >
TimerStop:
speech:
text: >
endif %}{%
endif %}{%
service: script.1689339492373
data_template:
TimerDuration:
speech:
text: >
endif %}{%
endif %}{%
endif %}{% endif %}
ShoppingListAddItem:
service: "shopping_list.add_item"
speech:
text: "{{shop_item}} added to shopping list"
TestIntent:
service: notify.mobile_app_galaxy_watch4_classic_5epz
message: test
speech:
text: "Test completed"
contents of : /config/custom_sentences/en/timer_start.yaml
language: "en"
intents:
TimerStart:
#All times
- sentences:
- "(start|set|would) [a] timer (for|from) {hours} (hour|hours) [and] {minutes} (minute|minutes) [and] {seconds} (second|seconds) [[want|can] do] [start]"
#All one hour
- sentences:
- "(start|set|would) [a] timer (for|from) {hours} (hour|hours) [[want|can] do] [start]"
slots:
seconds: 0
minutes: 0
#All one minute
- sentences:
- "(start|set|would) [a] timer (for|from) {minutes} (minute|minutes) [[want|can] do] [start]"
slots:
seconds: 0
hours: 0
#All one second
- sentences:
- "(start|set|would) [a] timer (for|from) {seconds} (second|seconds) [[want|can] do] [start]"
slots:
minutes: 0
hours: 0
- sentences:
- "(start|set|would) [a] timer (for|from) {minutes} (minute|minutes) [en] {seconds} (second|seconds) [[want|can] do] [start]"
slots:
hours: 0
- sentences:
- "(start|set|would) [a] timer (for|from) {hours} (hour|hours) [en] {minutes} (minute|minutes) [[want|can] do] [start]"
slots:
seconds: 0
#Halven
- sentences:
- "(start|set|would) [a] timer (for|from) [{minutes}][ ]([en] [one] half | [en] [one] halve) minute [[want|can] do] [start]"
- "(start|set|would) [a] timer (for|from) (0,5|0.5) minute [[want|can] do] [start]"
slots:
hours: 0
seconds: 30
- sentences:
- "(start|set|would) [a] timer (for|from) (anderhalve|anderhalf) minute [[want|can] do] [start]"
- "(start|set|would) [a] timer (for|from) (1,5|1.5) minute [[want|can] do] [start]"
slots:
hours: 0
seconds: 30
minutes: 1
- sentences:
- "(start|move|would) [a] timer (for|from) [{hours}][ ]([en] [one] half | [en] [one] halve) hour [[want|can] do] [start]"
slots:
minutes: 30
seconds: 0
- sentences:
- "(start|move|would) [a] timer (for|from) (anderhalve|anderhalf) hour [[want|can] do] [start]"
- "(start|move|would) [a] timer (for|from) (1,5|1.5) hour [[want|can] do] [start]"
slots:
hours: 1
seconds: 0
minutes: 30
lists:
seconds:
range:
to: 120
minutes:
range:
to: 120
hours:
range:
to: 24
contents of : /config/custom_sentences/en/timer_stop.yaml
language: "en"
intents:
TimerStop:
- sentences:
- "(stop|cancel|would) [the|my] {timer} timer[s] [[want|can] do] [stop|turn off]"
- sentences:
- "(stop|cancel|would) [the|my] timer [[want|can] do] [stop|turn off]"
slots:
lists:
timer:
values:
- in: "first"
out: "timer.timer1"
- in: "second"
out: "timer.timer2"
- in: "third"
out: "timer.timer3"
- in: "all"
contents of /config/custom_sentences/en/timer_duration.yaml
language: "en"
intents:
TimerDuration:
- sentences:
- "(how long|how much time) is left on [my|the] {timer} timer"
- "how long does the {timer} timer have left"
- sentences:
- "(how long|how much time) is left on [my|the] timer[s]"
- "show my timer[s]"
slots:
lists:
timer:
values:
- in: "first"
out: "timer.timer1"
- in: "second"
out: "timer.timer2"
- in: "third"
out: "timer.timer3"
- in: "all"
contents of timer start script :
sequence:
data_template:
entity_id: >
'paused' %} timer.timer1 {% elif states('timer.timer2') != 'active' and
states('timer.timer2') != 'paused' %} timer.timer2 {% else %}
timer.timer3 {% endif%}
entity_id: >
'paused' %} input_boolean.timer1_actief {% elif states('timer.timer2')
input_boolean.timer2_active {% else %} input_boolean.timer3_active {%
endif%}
mode: single
contents of timer stop script :
sequence:
- choose:
- conditions:
value_template: >-
value_template: >-
sequence:
entity_id: >
input_boolean.timer3_active {% elif states(entity_id) ==
'active' and entity_id != 'timer.timer0'%} {{ "input_boolean." +
default:
mode: single
Here’s the custom sentence to test the watch notification :
contents of : /config/custom_sentences/en/test.yaml
language: "en"
intents:
TestIntent:
- sentences:
- "testing intent[s]"
Hi everyone,
For those interested, I updated the timer script. I dug into Assist’s functionality a bit more.
I created files for both Dutch and English.
Currently, there is an error when stopping timers. Assist will respond the timer is not running, but stops the timer(s) anyway.
P.s. This is my first attempt at a Github repo, please be nice :).
I want to be nice, and let you know your github link does not appear to work.
It seems your repository is set on private. Set it to public and the link should work.
