Set actionable notification dynamically
I am trying the generate an automation, which should send a notification to my iphone, when a sensor != ‘success’. Furthermore I want to have a button which should trigger a switch in HA. I have 7 different thermostats and therefore I want to make the notification and button dynamically (should only get shown when sensor != 'success).
Attached you find my automation, where I have some issues. I believe my syntax of the for and if in the data of ‘Send Notification’, “Wait for Button Response” and “Perform the Selected Action” is wrong. Nevertheless, if i copy it in the development tools it seems to be ok?
alias: Thermostat Notification with Conditional Actions
description: Notify and handle thermostat valve adaptation dynamically.
  - platform: state
    entity_id:
      - sensor.thermostat_badezimmer_valve_adapt_status
      - sensor.thermostat_buro_valve_adapt_status
      - sensor.thermostat_schlafzimmer_valve_adapt_status
      - sensor.thermostat_gastezimmer_valve_adapt_status
      - sensor.thermostat_vorzimmer_valve_adapt_status
      - sensor.thermostat_wohnzimmerfenster_valve_adapt_status
      - sensor.thermostat_wohnzimmertur_valve_adapt_status
condition:
  - condition: template
    value_template: >
      {% set thermostats = {
        'bathroom': {'sensor': 'sensor.thermostat_badezimmer_valve_adapt_status', 'action_id': 'ADOPT_BATHROOM', 'switch': 'switch.thermostat_badezimmer_valve_adapt_process'},
        'buro': {'sensor': 'sensor.thermostat_buro_valve_adapt_status', 'action_id': 'ADOPT_BURO', 'switch': 'switch.thermostat_buro_valve_adapt_process'},
        'schlafzimmer': {'sensor': 'sensor.thermostat_schlafzimmer_valve_adapt_status', 'action_id': 'ADOPT_SCHLAFZIMMER', 'switch': 'switch.thermostat_schlafzimmer_valve_adapt_process'},
        'gastezimmer': {'sensor': 'sensor.thermostat_gastezimmer_valve_adapt_status', 'action_id': 'ADOPT_GASTEZIMMER', 'switch': 'switch.thermostat_gastezimmer_valve_adapt_process'},
        'vorzimmer': {'sensor': 'sensor.thermostat_vorzimmer_valve_adapt_status', 'action_id': 'ADOPT_VORZIMMER', 'switch': 'switch.thermostat_vorzimmer_valve_adapt_process'},
        'wohnzimmerfenster': {'sensor': 'sensor.thermostat_wohnzimmerfenster_valve_adapt_status', 'action_id': 'ADOPT_WOHNZIMMERFENSTER', 'switch': 'switch.thermostat_wohnzimmerfenster_valve_adapt_process'},
        'wohnzimmertur': {'sensor': 'sensor.thermostat_wohnzimmertur_valve_adapt_status', 'action_id': 'ADOPT_WOHNZIMMERTUR', 'switch': 'switch.thermostat_wohnzimmertur_valve_adapt_process'}
      {{ thermostats | selectattr('sensor', 'defined') | selectattr('sensor', '!=', 'success') | list | length > 0 }}
  - alias: "Set up dynamic variables for actions"
    variables:
      thermostats:
        bathroom:
          sensor: 'sensor.thermostat_badezimmer_valve_adapt_status'
          action_id: 'ADOPT_BATHROOM'
          switch: 'switch.thermostat_badezimmer_valve_adapt_process'
        buro:
          sensor: 'sensor.thermostat_buro_valve_adapt_status'
          action_id: 'ADOPT_BURO'
          switch: 'switch.thermostat_buro_valve_adapt_process'
        schlafzimmer:
          sensor: 'sensor.thermostat_schlafzimmer_valve_adapt_status'
          action_id: 'ADOPT_SCHLAFZIMMER'
          switch: 'switch.thermostat_schlafzimmer_valve_adapt_process'
        gastezimmer:
          sensor: 'sensor.thermostat_gastezimmer_valve_adapt_status'
          action_id: 'ADOPT_GASTEZIMMER'
          switch: 'switch.thermostat_gastezimmer_valve_adapt_process'
        vorzimmer:
          sensor: 'sensor.thermostat_vorzimmer_valve_adapt_status'
          action_id: 'ADOPT_VORZIMMER'
          switch: 'switch.thermostat_vorzimmer_valve_adapt_process'
        wohnzimmerfenster:
          sensor: 'sensor.thermostat_wohnzimmerfenster_valve_adapt_status'
          action_id: 'ADOPT_WOHNZIMMERFENSTER'
          switch: 'switch.thermostat_wohnzimmerfenster_valve_adapt_process'
        wohnzimmertur:
          sensor: 'sensor.thermostat_wohnzimmertur_valve_adapt_status'
          action_id: 'ADOPT_WOHNZIMMERTUR'
          switch: 'switch.thermostat_wohnzimmertur_valve_adapt_process'
  - alias: "Send Notification"
    service: notify.mobile_app_iphone_von_franz
      title: Thermostat Alert
      message: >
        {% set problem_thermostats = thermostats %}
        {% for key, data in problem_thermostats.items() %}
          {% if states(data.sensor) != 'success' %}
            - {{ key.capitalize() }}: {{ states(data.sensor) }}
          {% endif %}
        {% endfor %}
        actions:
          {% for key, data in thermostats.items() %}
              - action: "{{ data.action_id }}"
                title: "Start {{ key.capitalize() }} Adoption"
            {% endif %}
          {% endfor %}
  - alias: "Wait for Button Response"
    wait_for_trigger:
        - platform: event
          event_type: mobile_app_notification_action
          event_data:
        {% endif %}
      {% endfor %}
  - alias: "Perform the Selected Action"
    choose:
        - conditions: "{{ wait.trigger.event.data.action == data.action_id }}"
          sequence:
            - service: switch.turn_on
                entity_id: "{{ data.switch }}"
        {% endif %}
      {% endfor %}
Hope somebody can help me with it. (If I do not make it dynamically (so I always see all thermostats status and all buttons) I made it already work… (Y)
