Set automation for a sonoff pow 16
Hi
I’m trying to make an automation for a sonoff device flashed with tasmota.
The device is a pow 16 and I can turn it on/off manually.
But what I want is to turn it on or off at a certain time depending on the season.
For now I’m focusing in turning it on and off at a certain time, but I can’t seem to figure out how to make it work:
The automation.yaml:
  alias: Sonoff_Vestiario_Winter_On
  - at: '21:13'
    platform: time
   - alias: 'teste'
     service: switch.turn_on
     #entity_id: switch.Sonoff_vestiario
     entity_id: switch.Vestiario_DVES_3E51D5
I tried with the two entity_id but none of them worked
The information page on the sonoff:
This is the switch:
This is the automation
I think I’m failing to get the correct id? or is it something else?
Thanks in advance
Get the ID from the dev-state page. It should be all lower case.
Also I don’t think you should have an alias under action.
Finally your indentation seems wrong.
Thanks, that did the trick.
- id: '1556478149414'
    - at: '23:50:30'
    platform: time
  condition:
  - condition: state
    entity_id: input_select.seasons
    state: Winter
     entity_id: switch.sonoff
But this creates a problem, I have more Sonoff device to integrate, how can I change the id?
And could you correct my indentation, please
Not my strong point! Is it working now? If so, leave it alone. If not take a hard look at the documentation, that’s what i would have to do to be sure.
EDIT: sorry should have added the next sonoff device should be given a new name.
How do I rename the sonoff device?
