Hi folks! I am trying to install HA on a RPi4 on a SSD. I am trying to set Boot from USB, but when I start the RPi with the Sd card into it, I get “failed to open device ‘sd card’ (cmd 81a0010 status 0)”. No green or red screen.
Are you trying to boot from sd card to change over to boot from usb? If so an it isn’t working after flashing the sd card you almost certainly have a faulty as card.
I am trying to boot from SSD in the end. So I created a SD card with USB Boot code. The problem is I do not get a green screen or a red screen like I believe I should. Instead I get this message: “failed to open device ‘sd card’ (cmd 81a0010 status 0)”.
I tried with a few different SD cards, including one which I tested by installing HA on it beforehand.
