I have an HMIP BSL Switch actuator for brand switches, with signal light.
The light is on ch 8 I guess .
So how can I set the light e.g. to RED.
I found an service “Homematic(IP) Local: Set device value”…
But it doesn’t work. Any hints, how I set the color ?
Hi!
The HmIP-BSL device is offering 2 different RGB light entities - one is on ch8, the other on ch12.
To set the color of Homematic entity light.00xxxxxxxxxxxx_8 (i.e. the channel 8 light of your BSL), I am e.g. using the following action in an automation:
- service: light.turn_on
rgb_color:
- 255
- 0
- 0
brightness_pct: 100
entity_id: light.00xxxxxxxxxxxx_8
Color name can be used too:
color_name: blue
brightness_pct: 89
entity_id: light.kuhlschrank_warnung
Other colors are black, blue, green, turquoise, red, purple, yellow, white.
In the recent version, there is also the command “effect”:
rgb_color:
- 255
- 255
- 255
brightness_pct: 60
effect: test
Now, what are the right terms for “effect”?
Thanks a lot!
