I’m trying to calibrate a temperature sensor that is off, but it seams that I can’t send negative values?
Here is what I’m sending:
"node_id": 2,
"parameter": 66,
"value": "-2"
And here is the log output:
16-12-14 23:16:40 homeassistant.core: Error doing job: Future exception was never retrieved
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/core.py", line 1045, in execute_service
service_handler.func(service_call)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/zwave/__init__.py", line 462, in set_config_parameter
node.set_config_param(param, value, size)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/openzwave-0.3.1-py3.4.egg/openzwave/node.py", line 953, in set_config_param
return self._network.manager.setConfigParam(self.home_id, self.object_id, param, value, size)
File "src-lib/libopenzwave/libopenzwave.pyx", line 3703, in libopenzwave.PyManager.setConfigParam (src-lib/libopenzwave/libopenzwave.cpp:27697)
OverflowError: can't convert negative value to uint32_t
