I am writing a script that should pause based on the numeric value of an input_select helper. The MWE looks as follows:
sequence:
- delay:
hours: 0
minutes: {{ float(states("input_select.music_duration")) }}
seconds: 0
milliseconds: 0
However, this yields an error:
Message malformed: expected float for dictionary value @ data[‘sequence’][0][‘delay’][‘minutes’]
I do not understand the problem since the input_select value is in fact a float and the template editor returns true for
{{ float(states("input_select.music_duration")) is float }}
