Set DS1307 time to specific value
I’m trying to set up an ESP32 with a DS1307 RTC module.
The ESP32 will not have any other time source as no network is available. I’ve configured the ESP32 to act as an access point and I’ve enabled the web server so I can set some configuration items.
I’ve configured a datetime template where I can specify the current date and time. I would like to sync this user-provided value to the system clock (and RTC) so I can update the time this way. Once it’s set, the system should read the time from the RTC on boot. I can’t seem to find how to set the current system time to an explicit value, so I can then write it to the ds1307.
The DS1307 seems to be halted now. I assume that’s because no initial time has been configured on it?
Currently when the esp32 boots, it shows the following relevant lines:
[11:48:59][C][ds1307:013]: Setting up DS1307...
[11:49:00][D][ds1307:092]: Read  00:00:00 2000-01-01  CH:ON RS:3 SQWE:OFF OUT:OFF
[11:49:00][W][ds1307:037]: RTC halted, not syncing to system clock.
I have the following lines in my config regarding time:
esphome:
  platform: ESP32
  board: esp32doit-devkit-v1
logger:
  level: DEBUG
wifi:
  ap:
    ssid: 'My ESP32'
    password: 'secret'
    ap_timeout: 10s
i2c:
  sda: GPIO21
  scl: GPIO22
  scan: true
time:
  - platform: ds1307
    timezone: Europe/Brussels
    on_time_sync:
      then:
        - logger.log: "DS1307 time synchronised"
Same issue for me. ESP32 with limited internet availability needs to be set manually.
I let the user enter date and time (global variables as int) via pushbuttons.
And then the magic should happen and the DS1307 should get the new date time.
How can this be done? Any ideas
@RikT @Thomas717
You can do it using this component
Until it get merged into main branch you need to specify this pr using external_component:
external_components:
  - source: github://pr#7621
    refresh: 30s
    components: [ time ]
time:
  - platform: ds1307
datetime:
    type: datetime
    name: Pick a Datetime
    optimistic: yes
    on_value:
      then:
        lambda: |-
          id(ds1307_time).set_time(x);
button:
    name: "Press to print current date/time"
    on_press:
      then:
        - logger.log:
            format: "local: %s"
            args: [ 'id(ds1307_time).now().strftime("%Y-%m-%d %H:%M:%S").c_str()' ]
Thanks to rfdarter :+1:
There seems to be a bug in pr#7621 related to setting of the hour.
Here is my lambda code:
        int hour = id(dt_hour).state;
        ESP_LOGD("main", "hour is: %d", hour);
        id(rtc_time).set_time(year, month, day, hour, minute, 0);
        auto time = id(rtc_time).now();
        id(current_time).publish_state(time.strftime("%Y-%m-%d / %H:%M"));
The log show hour is “N” but the time is set to “N-1”. Entering hour = 0 is ignored.
I am using a DS3231 but should be the same as DS1307 from a programming point of view.
I too have a webserver application that requires date and time independent of the internet.
I could create a custom component to write to the DS3231 registers but that should not be necessary.
I could just add one to hour but that seems like a hack.
Here is a complete example of how to set time on a DS3231/DS1307 RTC without an internet connection and not requiring pr#7621
esphome:
  friendly_name: Set Time Demo
  platformio_options:
    board_build.arduino.memory_type: qio_opi
    board_upload.maximum_ram_size: 524288
  on_boot:
    - priority: 200
      then:
        - ds1307.read_time:
esp32:
  board: esp32-s3-devkitc-1
  variant: esp32s3
  flash_size: 16MB
  #partitions: "/config/esphome/default_16MB.csv"
  framework:
    type: arduino
psram:
  mode: octal
  speed: 80MHz
# Enable logging
logger:
  level: debug
wifi:
  ap:
    ssid: "Demo"
    password: "password"
web_server:
  port: 80
  version: 3
  ota: true
  log: true
  local: true
  sorting_groups:
    - id: sorting_group_time
      name: "Current Date/Time"
      sorting_weight: 10
i2c:
  sda: GPIO01
  scl: GPIO02
  scan: true
time:
  - platform: ds1307
    timezone: "unknown"
number:
  # Set Date Times
    web_server:
      sorting_group_id: sorting_group_time
    optimistic: true
    mode: box
    min_value: 2025
    max_value: 2100
    step: 1
    initial_value: 2025
    restore_value: true
    web_server:
    optimistic: true
    mode: box
    min_value: 1
    max_value: 12
    step: 1
    initial_value: 1
    web_server:
    optimistic: true
    mode: box
    min_value: 1
    max_value: 31
    step: 1
    initial_value: 1
    web_server:
    optimistic: true
    mode: box
    min_value: 0
    max_value: 23
    step: 1
    initial_value: 12
    web_server:
    optimistic: true
    mode: box
    min_value: 1
    max_value: 59
    step: 1
    initial_value: 0
text_sensor:
    web_server:
    lambda: |-
      return time.strftime("%Y-%m-%d / %H:%M");
button:
    web_server:
    on_press:
      then:
        - lambda: |-
            ESP_LOGD("main", "Button Pressed");
            int year = id(dt_year).state;
            int month = id(dt_month).state;
            int day = id(dt_day).state;
            int tmp;
            int minute = id(dt_minute).state;
            year = (year - 2000) / 10 * 16 + ((year - 2000) % 10);
            month = month / 10 * 16 + (month % 10);
            day = day / 10 * 16 + (day % 10);
            hour = hour / 10 * 16 + (hour % 10);
            minute = minute / 10 * 16 + (minute % 10);
            Wire.beginTransmission(0x68);
            Wire.write(0);  // Start at register 0
            Wire.write(0);       // Seconds
            Wire.write(minute);  // Minutes
            Wire.write(hour);    // Hours
            Wire.write(1);   // Day of the week
            Wire.write(day);     // Day of the month
            Wire.write(month);  // Month
            Wire.write(year);   // Year
            Wire.endTransmission();
        - ds1307.read_time:
        - lambda: |-
Hi. I downloaded your code. There is one problem. The hour is set with an offset. For example, I want to set 1 hour but it sets 3 hours for me
08:30:07	[D]	[button:010]
'Set Time' Pressed.
08:30:07	[D]	[main:089]
Button Pressed
08:30:07	[D]	[ds1307:092]
Read  01:00:00 2025-01-01  CH:OFF RS:3 SQWE:ON OUT:ON
08:30:07	[D]	[time:051]
Synchronized time: 2025-01-01 03:00:00
Double check that you have set the time zone to “unknown”
Thank you, it’s my mistake. Everything works!
Then if there is synchronization with the home assistant server, the time will be 2 hours behind. :grinning: Paradox?
I hope you notice that the example Esphome code has no connection to Home Assistant. The ESPHOME board synchronizes to ds1307 time on_boot with ds1307.readtime. I added a Home Assistant Wifi connection just to debug my code as the Wifi update is faster and it saves reconnecting to the WiFi access point on each iteration. After debug, the code is set to just Wifi AP access. By the way, do not use an ds1307 with a 3.3V ESP32 as it not reliable. Instead use the ds3231 with is designed to operate at 3.3V.
Yes, I noticed that the board has no connection with the server and does not receive time from it. I myself added part of the code to receive time from the home assistant.Thus, I checked how time behaves in esp32.When setting the time manually, everything works fine. If a connection with a home assistant appears at that time, the time zone is not taken into account.
Thanks. I did some modifications to use with esp-idf framework
on_press:
      then:
         - lambda: |-
              int tmp;
              i2c_cmd_handle_t cmd = i2c_cmd_link_create();
              i2c_master_start(cmd);
              i2c_master_write_byte(cmd, (0x68 << 1) | I2C_MASTER_WRITE, true);
              i2c_master_write_byte(cmd, 0x0, true); // Start at register 0
              i2c_master_write_byte(cmd, 0x0, true); // Seconds
              i2c_master_write_byte(cmd, minute, true); // Minutes
              i2c_master_write_byte(cmd, hour, true); // Hours
              i2c_master_write_byte(cmd, 0x1, true); // Day of the week
              i2c_master_write_byte(cmd, day, true); // Day of the month
              i2c_master_write_byte(cmd, month, true); // Month
              i2c_master_write_byte(cmd, year, true); // Year
              i2c_master_stop(cmd);
              i2c_master_cmd_begin(I2C_NUM_0, cmd, 1000 / portTICK_PERIOD_MS);
              i2c_cmd_link_delete(cmd);
Used GrahamS example and adopted to a 8266 nodemcu.
Have to say it worked better than I thought.
( and better than I deserved! )
Thanks to all!!
New to all this and forever learning…
