Hi everybody,
I have a sensor for the internet speed. And I want it to become unknown after 15 minutes, which is easily done with a timer node. But if it gets unavailabl, home assistant throws an error. Is there a “correct” way to do this?
Here is the errors:
Logger: homeassistant.components.sensor
Source: components/sensor/__init__.py:595
Integration: Sensor (documentation, issues)
First occurred: 11:29:21 (2 occurrences)
Last logged: 11:29:21
Error adding entities for domain sensor with platform nodered
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 591, in state
numerical_value = int(value)
ValueError: invalid literal for int() with base 10: 'unknown'
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 510, in async_add_entities
await asyncio.gather(*tasks)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 750, in _async_add_entity
await entity.add_to_platform_finish()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1004, in add_to_platform_finish
self.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 746, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 808, in _async_write_ha_state
state = self._stringify_state(available)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 752, in _stringify_state
if (state := self.state) is None:
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 595, in state
raise ValueError(
ValueError: Sensor sensor.breitbandmessung_download has device class 'data_rate', state class 'measurement' unit 'Mbit/s' and suggested precision 'None' thus indicating it has a numeric value; however, it has the non-numeric value: 'unknown' (<class 'str'>)
Error doing job: Task exception was never retrieved
raise ValueError(
