This is a blueprint, that allows to set the temperature of a climate device to a given input_number at an input_datetime.
I use it to heat the rooms of my children for 30 minutes in the morning, when they get up and ready for school.
The duration is entered as string in the format hh:mm:ss
blueprint:
name: Heat for certain time
description: Turn on heating for a given amount of time.
domain: automation
input:
datetime:
description: A datetime input that defines the time at which the heating is turned on.
selector:
entity:
domain: input_datetime
thermostat:
name: Thermostat to control
description: climate entity for which the temperature will be set.
selector:
entity:
domain: climate
heating_time:
description: How long will the heating be turned on.
temp_on:
name: Target Temperature on
description: The temperature to set for heating.
selector:
entity:
domain: input_number
temp_off:
name: Target Temperature off
description: The temperature to set when not heating.
selector:
entity:
mode: single
variables:
temp_on: !input temp_on
temp_off: !input temp_off
platform: time
at: !input datetime
- service: climate.set_temperature
hvac_mode: heat
temperature: '{{ states(temp_on) }}'
entity_id: !input thermostat
- delay: !input heating_time
hvac_mode: heat
temperature: '{{ states(temp_off) }}'
