Is possible to set the “initial” args of the date time input as a template? in particular I would like to set the time as now + 1 hour.
No, but you can use an automation triggered by the homeassistant start event to set the value of an input_datetime to the current time, or even the current time + one hour.
Personally I find the input_datetime difficult to use. You can’t set both the date and time with a single template, so now() will advance slightly between the two, making it possible to get inconsistent data. I prefer to use an input_number to record a timestamp, since very often datetimes are converted to timestamps when they’re used anyway.
input_number:
ha_start_timestamp:
name: HA Start Timestamp
min: 0
max: 5000000000
automation:
- alias: Record HA start timestamp
platform: homeassistant
event: start
service: input_number.set_value
entity_id: input_number.ha_start_timestamp
data_template:
value: "{{ as_timestamp(now()) }}"
If you’d rather record the start time plus one hour, then:
value: "{{ as_timestamp(now()) + 60*60 }}"
Update: You can now that I added that feature.
