Hi, I would like to set a light, and all of its effects a static brightness based on the Sun, Sunset or Sunrise.
Is this possible in ESPhome config?
Thanks Nick, could you advise the best way to integrate this for the Light.
I want to integrate it so that no matter what light effect is called, the brightness remains the same based on the sun condition.
Right now, when the effect is called, the brightness reverts back to its default.
Could you please show your yaml.
Sure,
esphome:
friendly_name: playbulb-candle-1
# on_boot:
# priority: 600
# then:
# - light.control:
# id: led
# state: on
# effect: BOOT
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key:
ota:
password:
wifi:
networks:
- ssid: !secret wifi_ssid
bssid:
fast_connect: true
on_connect:
- light.turn_on:
brightness: 100%
red: 0%
green: 100%
blue: 0%
effect: none
on_disconnect:
- light.control:
state: on
effect: ERROR
ap:
ssid: "Playbulb-Candle-1"
password:
captive_portal:
light:
- platform: fastled_clockless
pin: 23
chipset: WS2812
num_leds: 1
rgb_order: GRB
# restore_mode: ALWAYS_OFF
effects:
- pulse:
- pulse:
transition_length: 0.5s
update_interval: 0.5s
min_brightness: 0%
max_brightness: 100%
- pulse:
# transition_length: 1s # defaults to 1s
update_interval: 2s
# - pulse:
# name: "Asymmetrical Pulse"
# on_length: 1s
# off_length: 500ms
# update_interval: 1.5s
# Use default parameters:
# - random:
# Customize parameters
# - random:
# name: "My Slow Random Effect"
# transition_length: 30s
# update_interval: 30s
# - random:
# name: "My Fast Random Effect"
# transition_length: 4s
# update_interval: 5s
# - random:
# name: Random Effect With Custom Values
# transition_length: 5s
# update_interval: 7s
# - pulse:
# name: "Fast Pulse"
# transition_length: 0.5s
# update_interval: 0.5s
# min_brightness: 40%
# max_brightness: 100%
# - pulse:
# name: "Slow Pulse"
# update_interval: 2s
# - strobe:
# name: Strobe Effect With Custom Values
# colors:
# - state: true
# brightness: 100%
# red: 100%
# green: 90%
# blue: 0%
# duration: 500ms
# - state: false
# duration: 250ms
# - state: true
# brightness: 100%
# red: 0%
# green: 100%
# blue: 0%
# duration: 500ms
# - flicker:
# name: Flicker Effect With Custom Values
# alpha: 95%
# intensity: 1.5%
# - addressable_rainbow:
# name: Rainbow Effect With Custom Values
# speed: 10
# width: 50
# - addressable_color_wipe:
# name: Color Wipe Effect With Custom Values
# colors:
# - red: 100%
# green: 100%
# blue: 100%
# num_leds: 1
# - red: 0%
# green: 0%
# blue: 0%
# num_leds: 1
# add_led_interval: 100ms
# reverse: false
# - addressable_scan:
# name: Scan Effect With Custom Values
# move_interval: 100ms
# scan_width: 1
# - addressable_twinkle:
# name: Twinkle Effect With Custom Values
# twinkle_probability: 5%
# progress_interval: 4ms
# - addressable_random_twinkle:
# name: Random Twinkle Effect With Custom Values
# progress_interval: 32ms
# - addressable_fireworks:
# name: Fireworks Effect With Custom Values
# update_interval: 32ms
# spark_probability: 10%
# use_random_color: false
# fade_out_rate: 120
# - addressable_lambda:
# name: "Wipe In"
# update_interval: 50ms
# lambda: |-
# static int x = 40;
# static int y = 0;
# if (initial_run) {
# x = 40;
# y = 0;
# it.all() = ESPColor::BLACK;
# if (x < it.size(), (y < it.size())) {
# it[x, y] = current_color;
# y += 1;
# x += 1;
# name: "Expo Light"
# update_interval: 16ms
# lambda: |-
# static int x = -400;
# float y = 0.35+0.65*exp(-pow(x, 2)/49000);
# int8_t r = ceil(current_color.r * y);
# int8_t g = ceil(current_color.g * y);
# int8_t b = ceil(current_color.b * y);
# it.all() = ESPColor(r,g,b);
# x += 1;
# if (x == 400)
# x = -400;
# name: "Wipe Out"
# update_interval: 12ms
# lambda: |-
# static int x = 0;
# x = it.size();
# if (x > 0) {
# x -= 1;
# it[x] = ESPColor::BLACK;
# - lambda:
# name: "ERROR"
# update_interval: 1s
# lambda: |-
# static bool state = false;
# auto call = id(led).turn_on();
# call.set_transition_length(500);
# call.set_rgb(1, 0, 0);
# if (!state) {
# call.set_brightness(1);
# } else {
# // If using 0, it freaks Home Assistant UI.
# call.set_brightness(0.01);
# call.perform();
# state = !state;
# - lambda:
# name: "BOOT"
# lambda: |-
# call.set_rgb(0, 1, 0);
# if (!state) {
# } else {
# call.perform();
# state = !state;
I am confused. The only code I see changing the effect is in on_disconnect. And I see nothing about sun.
I am trying like this.
light:
pin: 23
chipset: WS2812
num_leds: 1
rgb_order: GRB
on_sunrise:
- then:
brightness: 100%
Came up with this, will test.
sun:
latitude:
longitude:
on_sunset:
- then:
- light.turn_on:
brightness: 20%
effect: none
on_sunrise:
- then:
- light.turn_on:
brightness: 100%
effect: none
The problem with this is it does not check to see what state the sun is in after booting,
If I reboot the unit, its full brightness until the next sun cycle.
Any ideas on this one?
What I am trying to achieve is, preventing the light going above 20% brightness when the sun is below horizon, and then allowing the light to go to 100% when the sun is above the horizon, not matter what. I dont want anything to be able to override this.
Appreciate any input, been struggling now for a while with this.
Right now, it appears that the light does change static brightness based on the sun condition, however when an effect is called, like Fast Pulse, it seems to overwrite the brightness and just defaults to 100%, this is fine if the sun is above horizon, but it does it when the sun is below horizon too.
also, any idea why the led doesnt turn on on boot?
on_boot:
priority: 800
then:
- if:
condition:
- sun.is_above_horizon:
then:
light.turn_on:
brightness: 100%
green: 100%
else:
- light.turn_on:
brightness: 20%
green: 100%
light:
pin: 23
chipset: WS2812
num_leds: 1
rgb_order: GRB
priority: 800 is maybe a little early. Try later.
Thanks, I solved it with -1000
But, something weird is happening. I cannot get the color GREEN to show on boot.
It shows like a light blue?
on_boot:
priority: -1000
then:
- if:
condition:
then:
light.turn_on:
brightness: 100%
green: 100%
else:
- light.turn_on:
brightness: 20%
green: 100%
Does green work otherwise ?
Yes, green seems to work when instructed from HA
Damn, I fixed this by adding
color_correct: [60%, 60%, 60%]
to the fastled_clockless integration.
now, all thats outstanding is the effects overriding the brightness,
Could you help me with this. In my effects I am not really specifying a brightness. Is there a way to specify a brightness based on the sun condition for the effects?
effects:
- pulse:
- pulse:
min_brightness: 0%
- pulse:
update_interval: 2s
I think you need to use lambda effects
Thanks,
You mean actually write the Lamda code to check the state of the sun?
Yes, worth a try
