Hello
using python_scripts.set_state i write an automation that set a min/max temperature from midnight, but i don’t understand why the automation set both min and max sensor in a same time with the same value… FIXED
sensors:
min_temp_outside:
friendly_name: "Temperatura minima"
value_template: "0"
unit_of_measurement: °C
min_temp_outside_time:
friendly_name: "Ora temperatura minima"
value_template: "0:00:00"
max_temp_outside:
friendly_name: "Temperatura massima"
value_template: "0"
max_temp_outside_time:
friendly_name: "Ora temperatura massima"
automation:
alias: outside temp
description: ""
- platform: time
at: "00:00:00"
- platform: state
entity_id:
- sensor.balcone_temperatura
- platform: homeassistant
event: start
condition: []
- if:
- condition: or
conditions:
- condition: trigger
then:
- service: python_script.set_state
data_template:
entity_id: sensor.max_temp_outside
state: "{{ states.sensor.balcone_temperatura.state }}"
data_template:
entity_id: sensor.max_temp_outside_time
state: >-
{% set t = now() %} {% set giorno = strptime("%0.04d-%0.02d-%0.02d
%0.02d:%0.02d:%0.02d" | format(t.year, t.month, t.day, t.hour,
t.minute, t.second), "%Y-%m-%d %H:%M:%S") %} {{
giorno.strftime("%H:%M:%S") }}
data_template:
entity_id: sensor.min_temp_outside
data_template:
entity_id: sensor.min_temp_outside_time
state: >-
else:
- if:
- condition: template
value_template: >-
{{ states.sensor.balcone_temperatura.state | float >
states.sensor.max_temp_outside.state | float }}
then:
data_template:
data_template:
state: >-
strptime("%0.04d-%0.02d-%0.02d %0.02d:%0.02d:%0.02d" |
format(t.year, t.month, t.day, t.hour, t.minute, t.second),
"%Y-%m-%d %H:%M:%S") %} {{ giorno.strftime("%H:%M:%S") }}
- if:
value_template: >-
{{ states.sensor.balcone_temperatura.state | float <
states.sensor.min_temp_outside.state | float }}
then:
data_template:
data_template:
state: >-
mode: single
