Trust
1
Hi guys
at the moment my Home Assistant runs mostly with sensors from the forum. Copy and Past is very simple.
But now I want to create a sensor with its own status and learn how it works. Unfortunately my knowledge is not enough yet.
One of my sensors shows a decimal number based on the temperature difference. For me this is also OK.
template:
- sensor:
- name: "Temperature Difference"
unit_of_measurement: "°C"
state: >-
{{ ( states('sensor.govee_1_temperature')|float(0) - states('sensor.govee_2_temperature')|float(0) )|round(2) }}
But now I want to build a sensor for the family that shows “cold” for a negative number and “hot” for a positive number.
Should it not be too difficult, best still in blue and red
Thank you guys
Hellis81
(Hellis81)
2
if 1 is larger than 2, hot, else cold
state: >-
{{ 'hot' if ( states('sensor.govee_1_temperature')|float(0) > states('sensor.govee_2_temperature')|float(0) ) else 'cold' }}
Trust
3
Thank you for your answer, briefly I thought I understood. But I think I still have a lot to learn. It does not work yet.
I have guessed it is a binary sensor. Unfortunately, it is not displayed in the entities. I am doing something wrong.
template:
- sensor:
state: >-
- binary_sensor:
- name: "Temperature Difference Easy"
state: >-
Hellis81
(Hellis81)
4
Binary sensor can only be on/off.
You wanted hit or cold, so it has to be a sensor.
Trust
5
oh man i’m getting embarrassed.
it just doesn’t work.
I only see the first sensor
template:
- sensor:
state: >-
- sensor:
state: >-
EDIT: in the developer tools i found the template page. So I could see the syntax error.
Thanks again.
