substitutions:
devicename: d-mop
wifi:
networks:
- ssid: 'xxx'
password: 'xxxx'
- ssid: 'xxxxxx'
password: 'xxxxx'
reboot_timeout: 0s
domain: '.xxxxx'
ap:
ssid: "${devicename}"
password: xxxxxx
api:
reboot_timeout: 0s
ota:
password: xxxxxxxx
captive_portal:
logger:
esphome:
platform: esp32
board: esp32dev
on_boot:
- priority: 600
then:
# Start - sprawdzanie systemu i pojemników
- display.page.show: oled_start
- switch.turn_on: led_brudna_woda
- switch.turn_on: led_mopowanie
- switch.turn_on: led_czyszczenie
- switch.turn_on: led_zaloz_walek
- switch.turn_on: led_zbieranie
- switch.turn_on: led_zatkana_rura
- switch.turn_on: led_brak_wody
- delay: 2s
- switch.turn_off: led_brudna_woda
- switch.turn_off: led_mopowanie
- switch.turn_off: led_czyszczenie
- switch.turn_off: led_zaloz_walek
- switch.turn_off: led_zbieranie
- switch.turn_off: led_zatkana_rura
- switch.turn_off: led_brak_wody
- priority: 0
then:
# Podciaganie wody
- script.execute: podciaganie_wody
- delay: 3s
# Sprawdzanie stanu wody co 3s
- script.execute: sprawdzanie
- delay: 1s
# Gotowy
- display.page.show: oled_gotowy
- dfplayer.play_folder:
folder: !lambda 'return (id(language).state);'
file: 1
i2c:
sda: GPIO1
scl: GPIO3
web_server:
port: 80
version: 1
time:
- platform: homeassistant
number:
min_value: 1
max_value: 3
step: 1
optimistic: true
restore_value: true
# MOPOWANIE - PREDKOSCI
unit_of_measurement: '%'
min_value: 1
max_value: 100
step: 1
optimistic: true
restore_value: true
min_value: 1
max_value: 100
step: 1
optimistic: true
restore_value: true
unit_of_measurement: 's'
min_value: 1
max_value: 100
step: 1
optimistic: true
restore_value: true
# MOPOWANIE TURBO - PREDKOSCI
min_value: 1
max_value: 100
step: 1
optimistic: true
restore_value: true
min_value: 1
max_value: 100
step: 1
optimistic: true
restore_value: true
min_value: 1
max_value: 100
step: 1
optimistic: true
restore_value: true
# ZBIERANIE - PREDKOSCI
min_value: 1
max_value: 100
step: 1
optimistic: true
restore_value: true
min_value: 1
max_value: 100
step: 1
optimistic: true
restore_value: true
button:
- platform: restart
name: "Audio - Play 1"
on_press:
then:
file: 1
name: "Audio - Volume 10"
on_press:
then:
- dfplayer.set_volume: 10
name: "Audio - Volume 20"
on_press:
then:
- dfplayer.set_volume: 20
name: "Audio - Volume 30"
on_press:
then:
- dfplayer.set_volume: 30
name: "Audio - BASS"
on_press:
then:
- dfplayer.set_eq: BASS
switch:
# LED
- platform: gpio
name: 'LED - Mopowanie'
pin: GPIO27
- platform: gpio
name: 'LED - Zbieranie'
pin: GPIO26
- platform: gpio
name: 'LED - Czyszczenie'
pin: GPIO25
- platform: gpio
name: 'LED - Brak wody'
pin: GPIO16
- platform: gpio
name: 'LED - Brudna woda'
pin: GPIO14
- platform: gpio
name: 'LED - Załóż wałek'
pin: GPIO33
- platform: gpio
name: 'LED - Zatkana rura'
pin: GPIO12
# MOPOwANIE
optimistic: true
turn_on_action:
- switch.turn_off: switch_mopowanie_turbo
- switch.turn_off: switch_zbieranie
- switch.turn_off: switch_czyszczenie
- script.execute: mopowanie
turn_off_action:
- script.stop: mopowanie
- script.execute: stop
# MOPOWANIE TURBO
optimistic: true
turn_on_action:
- script.execute: mopowanie_turbo
turn_off_action:
- script.stop: mopowanie_turbo
# ZBIERANIE
optimistic: true
turn_on_action:
- script.execute: zbieranie
turn_off_action:
- script.stop: zbieranie
# CZYSZCZENIE
optimistic: true
turn_on_action:
- script.execute: czyszczenie
turn_off_action:
- script.stop: czyszczenie
# ------------------------------------------------------------------------------- SKRYPTY
script:
# Podciąganie wody
- id: podciaganie_wody
then:
# Włączanie pompki od wody na 3s
- output.set_level:
level: 50%
- delay: 3s
- output.turn_off: pompka_1_pwm
# Sprawdzanie poziomu wody
- id: sprawdzanie
then:
- repeat:
count: 99999
then:
# CZYSTA WODA - TYLKO LED
- if:
condition:
- binary_sensor.is_on: sensor_brak_wody
then:
- if:
condition:
- binary_sensor.is_off: sensor_brak_wody
then:
# CZYSTA WODA - MOPOWANIE
- if:
condition:
- switch.is_on: switch_mopowanie
then:
- delay: 2s
- display.page.show: oled_brak_wody
file: 6
# CZYSTA WODA - MOPOWANIE TURBO
- if:
condition:
- switch.is_on: switch_mopowanie_turbo
then:
- delay: 2s
file: 6
# CZYSTA WODA - CZYSZCZENIE
- if:
condition:
- switch.is_on: switch_czyszczenie
then:
- delay: 2s
file: 6
# PELNY ZBIORNIK BRUDNEJ WODY
- if:
condition:
- binary_sensor.is_on: sensor_brudna_woda
then:
- delay: 2s
- display.page.show: oled_brudna_woda
file: 7
- if:
condition:
- binary_sensor.is_off: sensor_brudna_woda
then:
- delay: 10s
# MOPOWANIE
- id: mopowanie
then:
- if:
condition:
- binary_sensor.is_on: sensor_przechyl
then:
- display.page.show: oled_mopowanie
file: 2
- delay: 2s
- output.set_level:
level: !lambda 'return (id(mopowanie_predkosc_silnik1).state, "%%");'
- output.set_level:
level: !lambda 'return (id(mopowanie_predkosc_silnik2).state, "%%");'
- repeat:
count: 9999
then:
- output.set_level:
level: 50%
- delay: 1s
- delay: !lambda 'return (id(mopowanie_czas_pompka1).state, "%s");'
# MOPOWANIE TURBO
- id: mopowanie_turbo
then:
- if:
condition:
then:
- display.page.show: oled_mopowanie_turbo
file: 3
- delay: 2s
- output.set_level:
level: !lambda 'return (id(mopowanie_turbo_predkosc_silnik1).state);'
- output.set_level:
level: !lambda 'return (id(mopowanie_turbo_predkosc_silnik2).state);'
- repeat:
count: 9999
then:
- output.set_level:
level: 50%
- delay: 1s
- delay: !lambda 'return (id(mopowanie_turbo_czas_pompka1).state);'
# ZBIERANIE
- id: zbieranie
then:
- if:
condition:
then:
- display.page.show: oled_zbieranie
file: 4
- delay: 2s
- output.set_level:
level: !lambda 'return (id(zbieranie_predkosc_silnik1).state);'
- output.set_level:
level: !lambda 'return (id(zbieranie_predkosc_silnik2).state);'
# CZYSZCZENIE
- id: czyszczenie
then:
- if:
condition:
- binary_sensor.is_off: sensor_przechyl
then:
- display.page.show: oled_czyszczenie
file: 5
- delay: 3s
- output.set_level:
level: 100%
- output.set_level:
level: 100%
# Włacza pompke
- output.set_level:
level: 50%
- delay: 240s
- delay: 60s
# STOP
- id: stop
then:
- output.turn_off: silnik_1_pwm
- output.turn_off: silnik_2_pwm
# OLED 1
image:
- file: images/esphome_logo.png
resize: 128x64
font:
- file: "gfonts://Roboto"
display:
- platform: ssd1306_i2c
model: "SSD1306 128x64"
address: 0x3D
update_interval: 1s
pages:
- id: oled_start
lambda: |-
it.print(64, 5, id(font_18), TextAlign::CENTER_HORIZONTAL, "TurboMop 3000");
it.print(64, 35, id(font_14), TextAlign::CENTER_HORIZONTAL, "wykonal: Wojtek");
- id: oled_gotowy
lambda: |-
it.print(64, 5, id(font_18), TextAlign::CENTER_HORIZONTAL, "Witaj");
it.print(64, 35, id(font_18), TextAlign::CENTER_HORIZONTAL, "Ola");
# Mopowanie
# it.printf(64, 32, id(font_18), TextAlign::CENTER_HORIZONTAL, "%.2fV", id(czujnik_zabrudzenia_adc).state);
- id: oled_mopowanie
lambda: |-
it.print(64, 32, id(font_18), TextAlign::CENTER, "Mopowanie");
# Mopowanie Turbo
- id: oled_mopowanie_turbo
lambda: |-
it.print(64, 5, id(font_18), TextAlign::CENTER_HORIZONTAL, "Turbo");
it.printf(64, 35, id(font_18), TextAlign::CENTER_HORIZONTAL, "Mopowanie");
# Zbieranie
- id: oled_zbieranie
lambda: |-
it.print(64, 32, id(font_18), TextAlign::CENTER, "Zbieranie");
# Czyszczenie
- id: oled_czyszczenie
lambda: |-
it.print(64, 5, id(font_18), TextAlign::CENTER_HORIZONTAL, "Czyszczenie");
it.printf(64, 35, id(font_18), TextAlign::CENTER_HORIZONTAL, "3 minuty");
# Pełny zbiornik brudnej wody
- id: oled_brudna_woda
lambda: |-
it.print(64, 5, id(font_18), TextAlign::CENTER_HORIZONTAL, "Wylej");
it.print(64, 35, id(font_18), TextAlign::CENTER_HORIZONTAL, "brudna wode");
# Brak wody
- id: oled_brak_wody
lambda: |-
it.print(64, 5, id(font_18), TextAlign::CENTER_HORIZONTAL, "Dolej");
it.print(64, 35, id(font_18), TextAlign::CENTER_HORIZONTAL, "czystej wody");
# Mowa
- id: oled_mowa_info
lambda: |-
it.printf(64, 32, id(font_30), TextAlign::CENTER, "%.0f", id(language).state);
# AUDIO
uart:
tx_pin: GPIO23
rx_pin: GPIO22
baud_rate: 9600
dfplayer:
output:
# Silnik 1 PWM Output (PCB_1 3.3V - mozna wieksze freq bo ma 3 fazy i niezalezne uzwojenia)
- platform: ledc
pin: GPIO4
frequency: 20kHz
channel: 2
# Silnik 2 PWM (PCB_2 - wyzsze freq indukcja na zwojach silnika nie pozwala, albo trzeba na 5V pcb)
- platform: ledc
pin: GPIO2
frequency: 20kHz
channel: 4
# Pompka 1 PWM
- platform: ledc
pin: GPIO15
frequency: 100Hz
channel: 6
fan:
- platform: speed
output: silnik_1_pwm
- platform: speed
output: silnik_2_pwm
- platform: speed
output: pompka_1_pwm
# SENSOR ZABRUDZENIA
- platform: adc
pin: GPIO39
name: "Czujnik - Zabrudzenia"
update_interval: 2s
attenuation: auto
# SENSOR BRUDNEJ WODY
- platform: adc
pin:
number: GPIO32
mode:
input: true
pullup: true
name: "Sensor - Brudna woda"
update_interval: 2s
attenuation: auto
binary_sensor:
# ----- STEROWANIE PRZYCISKAMI
# Przyciski 1 --> Mopowanie (ma się włączyc tylko jak czujnik wody pelny, brudnej wody pusty i mop w odpowiedniej pozycji) (trzeba podpompowac pompką inaczej caly czas ON)
- platform: gpio
name: "Przyciski 1 - Mopowanie / Turbo"
pin:
number: GPIO21
mode:
input: true
pulldown: true
on_multi_click:
# Krótkie naciśniecie guzika
- timing:
- ON for at most 1s
- OFF for at least 0.5s
then:
# Brak czystej wody - podciąganie
- if:
condition:
then:
- if:
condition:
then:
- switch.toggle: switch_mopowanie
- if:
condition:
then:
# Dodatkowo kiedy wlaczone mopowanie to ma wylaczyc
# Długie naciśnięcie guzika
- timing:
- ON for at least 1.5s
then:
- if:
condition:
then:
- if:
condition:
then:
- switch.toggle: switch_mopowanie_turbo
- if:
condition:
then:
# Przyciski 2 --> Zbieranie
- platform: gpio
name: "Przyciski 2 - Zbieranie"
pin:
number: GPIO19
mode:
input: true
pulldown: true
# Po nacisnieciu guzika
on_press:
then:
- switch.toggle: switch_zbieranie
# Przyciski 3 --> Czyszczenie (tylko kiedy w pozycji pionowej i pusty zbiornik brudnej wody)
- platform: gpio
name: "Przyciski 3 - Czyszczenie"
pin:
number: GPIO18
mode:
input: true
pulldown: true
on_press:
then:
- if:
condition:
then:
- if:
condition:
then:
- switch.toggle: switch_czyszczenie
# Przyciski 4 --> Zmiana języka
- platform: gpio
name: "Przycisk 4 - Zmiana języka"
pin:
number: GPIO17
mode:
input: true
pulldown: true
on_press:
then:
- number.increment: language
- display.page.show: oled_mowa_info
file: 1
- delay: 2s
# Czujnik - Brak wody (podlaczenie do chipu daje wysokie 3.3v na signal)
- platform: gpio
name: "Sensor - Woda"
pin:
number: GPIO36
mode:
input: true
filters:
- delayed_on: 2s
- delayed_off: 2s
# Czujnik - Brudna woda (zwykłe łączenie poprzez wode, nie mozna pulldown: true bo za małe napiecie płynie przez wode, trzeba filtrowac skoki napiecia filtrem)
# Bez pulldown ON na pustym zbiorniku
# Z pulldown OFF na pustym i OFF na pelnym
# Zamienione na ADC
lambda: |-
if (id(sensor_brudna_woda_adc).state > 0.4)
return true;
else if (id(sensor_brudna_woda_adc).state < 0.4)
return false;
filters:
- delayed_on: 10s
- delayed_off: 1s
# Czujnik - Przechyłu (zwykły przełącznik potrzeba pulldown, bez pulldown czasami glupieje)
- platform: gpio
name: "Sensor - Przechył"
pin:
number: GPIO13
mode:
input: true
pulldown: true
on_press:
then:
on_release:
then:
