I want a customized Noctis theme for the dashboard I use for my wall mounted FireHD so I can get the font-size set to 24px for everything in the dashboard that uses font-size: var(--paper-font-body1_-_font-size);
I copied the noctis.yaml and placed the copy into a new folder called noctis24 under the themes folder and renamed it noctis24.yaml and added the following lines to it
paper-font-body1_-_font-size: '24px'
font-size: "var(--paper-font-body1_-_font-size)"
I had accidentally left noctis: within the yaml then restarted HA and all of my dashboards and HA screens used 24px for the font-size. I renamed that part as noctis24: then restarted again and chose noctis24 as the theme for the wall mounted dashboard and left the rest as noctis. However, the font-size won’t change in the specified dashboard. The rest of HA is back to normal.
What am I doing wrong?
edit: I chose noctis24 as the theme in my profile and it changes all of HA immediately. Why won’t if grab the font-size of 24px just for the specified dashboard?
