value_template: "{{ is_state('sensor.time', states('input_slider.random_hour')|int ~ ':' ~ states('input_slider.random_minute')|int) }}"
is there a doc about the meaning of “~” in this config ?
I don’t really get what it means.
2nd question, just to clear something that could be obvious to everyone but me,
I guess that we can’t set the range/random inside the “at:” field ?
- alias: 'Turn off between midnight and midnight thirty'
- platform: time
at: '00:{{ range(0,30) | random | int }}:00'
- service: light.turn_off
entity_id: light.light_bulb
Hey @ViperRNMC,
I did use your example, but I cannot seem to get it to work. I keep getting an error, that Delay should not be in the Automation part. Is your example a script, or is it an automation??
I only use automation
alias: Turn on Living room Lights when sun gets dimmer
platform: numeric_state
entity_id: sun.sun
value_template: '{{ state.attributes.elevation }}'
below: 0.1
service: scene.turn_on
delay: '{{ ((range(0, 1) | random) | int) ~ ":" ~ ((range(5, 55) | random) | int) ~ ":" ~ ((range(5, 55) | random) | int) }}'
entity_id: 'scene.scn_liv_on1'
Gives me the following error:
Invalid config for [automation]: [delay] is an invalid option for [automation]. Check: automation->action->0->delay. (See ?, line ?). Please check the docs at https://home-assistant.io/components/automation/
So I am a little confused… (Yes, I do use the automation: !include_dir_list includes/automation/
option)
Can you put your light on it, @ViperRNMC?
Put the delay at the bottom or at the top, because the “service: scene.turn_on” should come right before the "entity_id: ‘scene.cn_liv_on1’
- delay: '{{ ((range(0, 1) | random) | int) ~ ":" ~ ((range(5, 55) | random) | int) ~ ":" ~ ((range(5, 55) | random) | int) }}'
entity_id: light.front_porch_landscape
Just did that, and getting the same error.
Can I see what you have right now?
Delay and service should have a "- " in front of them, because they are list items of “action:”
@BendedArrow, I already fixed it I Misstyped yaml.
- platform: numeric_state
entity_id: sun.sun
below: 0.1
- service: scene.turn_on
data_template: >-
entity_id: 'scene.scn_liv_on{{ ( range(1, 4)|random) }}'
# entity_id: 'scene.scn_liv_on1'
This is what i recent used for an vacation automation
# vakantie
- alias: Scene vakantie
- platform: state
entity_id: binary_sensor.woonkamer_motion_dark
to: 'on'
- platform: time
at: '22:00:00'
condition:
- condition: state
entity_id: input_boolean.vakantie
state: 'on'
- condition: or
conditions:
- condition: and
conditions:
- condition: state
state: 'on'
- condition: time
before: '22:00:00'
- condition: template
value_template: >
{{ trigger.platform == 'time' }}
- delay: "{% if trigger.platform == 'state' %}00:00:10{% else %}0{{ (range(0, 1)|random|int) }}:{{ (range(10, 59)|random|int) }}:{{ (range(10, 59)|random|int) }}{% endif %}"
- service_template: >
light.turn_{{ trigger.platform|replace('state', 'on')|replace('time', 'off') }}
entity_id: group.zithoek
- service: notify.user
data_template:
title: 'Home Assistant '
message: >
lichten {% if trigger.to_state.state == 'on' %}aan{% else %}uit{% endif %}
Whow! That looks nice too, @ViperRNMC!!!
Right now, I am automating my livingroom lights, so I don’t have to worry about too much automation for the holidays
No thanks
ROFLMAO, @ViperRNMC, and that is the beauty of systems like this. We can both use systems, that we think fit, and work with that. The beauty of open, isn’t it? But I sure will use some of your code!
Hi!
Been trying to format your code, would you please check for me if this is it? especially the nested conditions are a bit of a challenge…
- platform: state
to: 'on'
- platform: time
at: '22:00:00'
condition:
- condition: state
state: 'on'
- condition: or
conditions:
condition: and
conditions:
- condition: state
state: 'on'
- condition: time
before: '22:00:00'
value_template: >
- delay: >
{% endif %}
data_template:
title: 'Home Assistant'
message: >
if you post herre, please use the code </> button in the editor, to
changed my code, thx
Moving from Domoticz to HA, I wanted to recreate my ‘switch on lights and tv at randomish hours’ setup, for when I’m on vacation.
Found this topic, but it didn’t work for me - mostly since things have gotten new names since the OP posted the solution.
The following works for me, and I base everything off of a boolean to state if I’m home or not:
Added the following items to configuration.yaml, this defines the necessary input variables to use lateron:
input_number:
tv_end_random_hour:
name: TV End Hour during vacation
min: 0
max: 23
tv_end_random_min:
name: TV End Minute during vacation
min: 0
max: 59
tv_start_random_hour:
name: TV Start Hour during vacation
min: 0
max: 23
tv_start_random_min:
name: TV Start Minute during vacation
min: 0
max: 59
Added the following code to automations.yaml:
- alias: Set random TV start time on vacation
- platform: time
at: '18:30:00'
condition:
- condition: state
entity_id: input_boolean.vacation_mode
state: 'on'
- service: input_number.set_value
data_template:
entity_id: input_number.tv_start_random_hour
value: '20'
data_template:
entity_id: input_number.tv_start_random_min
value: '{{ (range(30, 40)|random) }}'
- alias: Set random TV end time on vacation
- platform: time
at: '18:30:00'
condition:
- condition: state
state: 'on'
data_template:
entity_id: input_number.tv_end_random_hour
value: '22'
data_template:
entity_id: input_number.tv_end_random_min
value: '{{ (range(00, 05)|random) }}'
- alias: TV on during vacation during vacation
platform: template
value_template: "{{ is_state('sensor.time', states('input_number.tv_start_random_hour')|int ~ ':' ~ states('input_number.tv_start_random_min')|int) }}"
condition:
- condition: state
state: 'on'
- data:
entity_id: switch.media_cabinet
service: switch.turn_on
- delay: 00:01:00
- data:
entity_id: media_player.tv
service: media_player.turn_on
- alias: TV off during vacation during vacation
platform: template
value_template: "{{ is_state('sensor.time', states('input_number.tv_end_random_hour')|int ~ ':' ~ states('input_number.tv_end_random_min')|int) }}"
condition:
- condition: state
state: 'on'
- data:
service: media_player.turn_off
- delay: 00:01:00
- data:
service: switch.turn_off
is this really working? I checked my logs and noticed an error that a delay in format HH:MM or HH:MM:SS is expected. If you take eg range(5,55) and pipe in to random (why pipe it to int afterwards?) than the first 5 numbers in the range will give only a single number (5,6,7,8,9) and that should fail the automation right?
This must have been an older thread/quote. All of my new delays make sure that double digits are returned.
-Carlo
Yes, this is what I do but is there a more elegant way to get number between say, 5 and 10 with a leading zero than this (which is a second out)
- delay: "00:0{{ (range(4, 9)|random|int) }}:59"
I don’t think so. I don’t think there is a way to apply a filter to specify the leading zero. I think this is the best bet right now and works pretty reliably.
