You can do this (using Python format strings):
{{ "00:%02d:00" % (range(5, 10) | random) }}
Which returns: 00:05:00
to 00:10:00
. The magic is %02d
which means print an integer with two digits, prepending with 0
to 00:10:00
. The magic is %02d
Just some ways to use the yaml capabilities:
- delay:
seconds: "{{ range(0, 120)|random|int }}"
- delay:
minutes: "{{ range(2, 36)|random|int }}"
Or even:
- delay: "{{ (range(0, 120) | random) | multiply(60) | timestamp_custom('%H:%M:%S',False) }}"
I try to get my lamp to turn off at a random moment between 23:00 and 00:00 hour.
This is wat i put in the automation.yaml
- id: '1586461625357'
alias: Lamp hal uit
description: ''
trigger: []
condition:
- after: '23:00:00'
condition: time
- delay: '{{ (range(4, 6)|random|int) }}:00'
- service: switch.turn_off
entity_id: switch.sonoff_1000c979c1
It doesnât work.
What am i doing wrong??
you a) have no trigger and b) do not pass data to your service call.
try this
alias: Lamp hal uit
platform: time
at: '23:00:00'
This automation:
- id: '1584825287024'
alias: Anwesenheitslicht aus (22:15 + 2..36 Minuten)
description: ''
- at: '22:15:00'
platform: time
condition: []
- delay: '{{ "00:%02d:00" % (range(2, 36) | random) }}'
- scene: scene.anwesenheitslicht_aus
should normally switch off at 22:15 + 2âŚ36 minutes.
But it switches always at 22:15, there is no delay. What am I doing wrong?
it shouldâŚ
try replacing delay
with wait_template
- I think itâs possible using sensor.time
p.s where did you get this constriction? never seen anything like that and it works
"00:%02d:00" % blah
It was a few post before mine: https://community.home-assistant.io/t/set-random-time-for-random-automatic-turning-off-lights-mimic-someone-is-home/3524/42
Okay thanks,
I am gonna tryâŚ
Now I tried:
- delay: '00:{{ range(0,3) | random | int }}{{ range(0,9) | random | int }}:00'
but that is also not working. Very strange because this is the way that is documented in this thread. Strange, strange!
I will look what wait_template is.
I think you need to do some debugging.
I changed your scriptâs action and it shows me correct data.
- service: persistent_notification.create
data_template:
message: '{{ "00:%02d:00" % (range(2, 36) | random) }}'
So it looks like the problem is in your delay
(and I cannot reproduce it - everything works as expected)
By the way, according to the docs you can use this
- delay:
minutes: '{{ range(2, 36) | random }}'
You are my hero! This is working fine, I donât know why!
I thought I used that before, but it didnât worked, but now it works.
Thank you!
Good!
Well, as a homework you can now compare the working code with what doesât work and learn some more about HA if you have time/desire
Read the docs, itâll save you from many troubles.
Sure I want to learn more about Home Assistant as it is really great. The time is the problem because two children want to play with their dad and donât want to share them with a computer.
maybe one dayâŚ
going for a walk with my little one as well
Iâve been using this automation/script for a couple of years now and it has been working flawlessly. Love it!
Automation:
alias: "Security: Vacation Lights Evening Simulation"
description: >-
Turn on script that simulates lights to look like the house is occupied.
https://community.home-assistant.io/t/set-random-time-for-random-automatic-turning-off-lights-mimic-someone-is-home/3524/7
- platform: sun
event: sunset
offset: "-01:15"
- platform: state
entity_id:
- alarm_control_panel.ha_alarm
to: armed_away
condition:
- condition: and
conditions:
- condition: state
entity_id: alarm_control_panel.ha_alarm
state: armed_away
- condition: sun
after: sunset
after_offset: "-01:15"
- service: script.turn_on
data: {}
entity_id: script.vacation_lights_evening
mode: single
Script:
alias: Vacation Lights Evening
sequence:
- repeat:
until:
- condition: or
conditions:
- condition: state
state: armed_home
- condition: time
after: "21:30:00"
before: "00:00:00"
sequence:
- service: scene.turn_on
data_template:
entity_id: scene.vacation_simulation_{{ (range(1, 4)|random) }}
- delay: >-
{{ ((range(0, 1) | random) | int) ~ ":" ~ ((range(5, 55) | random) |
int) ~ ":" ~ ((range(5, 55) | random) | int) }}
- delay: 00:{{ (range(1, 59)|random|int) }}:00
- service: light.turn_off
data: {}
entity_id: group.all_lights
mode: single
icon: mdi:home-analytics
@Noblewolf
Sorry for my English, is not my language.
How could I read your script? What time in minutes and how often and for how long is a light on, for example?
@B29 this section below controls the time. It will cause the changes to be random. The change could happen ever 5 minutes and 5 seconds to 1 hour 55 minutes and 55 seconds.
Then at the end of the script (in this case 00:00:00, or midnight)
This causes the lights to turn off within 1 hour. Some amount of time between 1 minute to 59 minutes.
