I’ve installed hass.io on a KVM and I successfully got it to boot.
The only problem is that I need to set a static IP. Is there any way to set it from the hass CLI or from the web GUI?
Can it not be set in your DHCP reservations on your router?
Another option.
# Configuration
## Automatic
You can use an USB drive with HassOS to configure network options, SSH access to the host and to install updates.
Format a USB stick with FAT32/EXT4/NTFS and name it `CONFIG` (in all capitals). Alternative you can create a `CONFIG` folder inside boot partition. Use the following directory structure within the USB drive:
```text
network/
modules/
modprobe/
udev/
authorized_keys
timesyncd.conf
hassos-xy.raucb
- The `network` folder can contain any kind of NetworkManager connection files. For more information see [Network][network.md].
- The `modules` folder is for modules-load configuration files.
- The `modprobe` folder is for modules configuration files (/etc/modprobe.d)
This file has been truncated. show original
