Set status of fan speed or status without trigger
Hello everyone I’m using this code to control a push button of an extractor hood with dry contact relays on the keys, then I created some binary sensors that are activated based on the voltage that reaches me from the wiring. Now when I manually press the first speed on the hood the binary sensor turns on, how do I set the fan status based on the turning on of the binary sensors without it being triggered by the home assistant
captive_portal:
switch:
  - platform: gpio
    pin: 25
    restore_mode: RESTORE_DEFAULT_OFF
    on_turn_on:
      then:
        - delay: 500ms
        - switch.turn_off: lucecappa
  - platform: gpio
    pin: 19
    on_turn_on:
      then:
        - delay: 500ms
        - switch.turn_off: speed1
  - platform: gpio
    pin: 26
    on_turn_on:
      then:
        - delay: 500ms
        - switch.turn_off: speed2
  - platform: gpio
    pin: 23
    on_turn_on:
      then:
        - delay: 500ms
        - switch.turn_off: speed3
  - platform: gpio
    pin: 16
    on_turn_on:
      then:
        - delay: 500ms
        - switch.turn_off: speed4
output:
    type: float
    write_action:
      - if:
          condition:
            lambda: return ((state == 0));
          then:
            # action for off
      - if:
          condition:
            lambda: return ((state > 0) && (state < 0.3));
          then:
            # action for speed 1
            - switch.turn_on: speed1
      - if:
          condition:
            lambda: return ((state > 0.3) && (state < 0.6));
          then:
            # action for speed 2
            - delay: 1.5s
            - switch.turn_on: speed2
      - if:
          condition:
            lambda: return ((state > 0.6) && (state < 0.9));
          then:
            # action for speed 3
            - delay: 1.5s
            - switch.turn_on: speed3
      - if:
          condition:
            lambda: return ((state > 0.9));
          then:
            # action for speed 4
            - delay: 1.5s
            - switch.turn_on: speed4
fan:
  - platform: speed
    output: custom_fan
    speed_count: 4
    on_turn_on:
      - if:
          condition:
            lambda: return (id(gamesroomfan).speed > 0.3);
          then:
binary_sensor:
- platform: gpio
  pin:
    number: 18
    mode: INPUT_PULLUP
  name: "Tasto Luce Cappa"
  filters:
      - delayed_on: 500ms
      - delayed_off: 500ms
  name: "Velocita 1 Stato Cappa"
  name: "Velocita Turbo Stato Cappa"
  - platform: adc
    name: "Prima Velocita Stato"
    pin: 34
    update_interval: 0.5s
    on_value_range:
    - above: 1.03
      then:
        if:
          condition:
            binary_sensor.is_on: StatoCappa
          then:
            - binary_sensor.template.publish:
                state: off
    - below: 0.09
      then:
        if:
          condition:
            binary_sensor.is_off: StatoCappa
          then:
                state: on
  - platform: adc
    pin: 35
    filters:
      - sliding_window_moving_average:
          window_size: 15
    on_value:
      then:
        - if:
            condition:
              lambda: 'return id(TurboStato).state < 1;'
            then:
                  state: on
            else:
                  state: off
