So up until 2 weeks ago I never even heard of Home Assistant much less Hass.io. I’ve been using Homebridge to get a few devices Homekit and life has been good for about the last 12 months or so. A couple of weeks back I added a second door sensor to my MyQ garage door hub and it stopped working correctly. As I was researching a fix I came across a video on Hass.io. I did some independent research and now I’m freaking hooked. This software is so damn cool and the possibilities seem endless. Long story short I was able to solve a nagging issue where an overextend house guest likes to turn our AC unit down way below I want it to be. I’ve asked a million times but this house guest still does it. I created the automation below to reset the target temperature in the house to 77 degrees every 10 mins. This works well, it does what I need but in the back of my head I don’t like this solution the way it is because it will blindly set the target temperature regardless if it is already set to 77. I would like to add a condition that will check to see if the temperature is set to a value lower then 77 and then fire the action. If the target temperature is 78 or higher then the automation will not fire.
The strategy you’ve chosen is to set the temperature to 77 every 10 minutes. I suggest you consider another strategy: set it to 77 only if the temperature is set to lower than 77. In other words, there’s no need to periodically check the temperature every 10 minutes. Make the automation’s trigger be the thermostat’s target temperature. If someone changes it to less than 77, the automation is triggered and sets it back to 77.
@123 Thanks for the input. I like your suggestion, ultimately that’s the path I would prefer but didn’t quite know how to get there from here. I’ll check out the Numeric State Trigger. Thanks again.
@123 you’re awesome, I really appreciate the guidance. Using your suggestion I was able to get the automation working exactly how I want it. The automation is triggered as soon as the temperature is set to a value below 77 degrees but it will wait 2 mins before resetting the temperature. It will also send an iOS notification when the action is executed.
