I would like to change the target temperature in an automation. The new temperature should be the current temperature from the thermostat or another temperature sensor, PLUS an offset value stored in a helper.
If I specify the value of the helper like this, it works:
But any attempt to add another value (from the thermostat or another temperature sensor) has not worked so far. Unfortunately I always get different error messages.
What is the correct format to process the temperature values of the thermostat or another temperature sensor?
Thanks again for your help!
It worked in the developer. Apparently a formatting error had crept into the automation.
How can I save the current temperature in another helper? Because so the set target temperature is always only added. This is then a little too hot for me!
You can create a sensor that is readily available for you. This would go in your configuration.yaml
If you use !include then template: would need to go away
Maybe I have expressed myself a little misleadingly…
…I would like to save the current target temperature in a helper.
Then set the current target temperature + offset and after a certain time or at a certain time, the old / normal target temperature (without offset) should be set again and activated.
