Set temperature and mode when turning on climate (Sensibo)
Hi all,
I am trying to set up an automation for my Sensibo unit so that it will set the temperature, the mode, and turn it on. At the moment, turning it on has to be a separate action as there isn’t a way to set the temperature etc while turning it on.
However, it seems the automation is setting the temperate and mode values but the device isn’t being turned on. I’m wondering if because it’s technically going out via the internet, the communication may be too slow for HA and it’s firing the command but nothing happens.
Anyway, I’m wondering with climate entities - is there a way to set the temperature etc when using the climate.turn_on service?
Alternatively, should I put some form of wait command between the actions?
Any advice would be greatly appreciated
Cheers
You can add a delay between actions
Did you resolve this? I have the same issue. New to HA.
Hi, Also wondering if you resolved this? It is frustrating that you can not set the target heat from an automation. Sigh…
Took me a while to find it but instead of choosing a device you fhave to choose a service then Climate / Set temperature and THEN choose your sznsibo device.
I completely forgot about this post until I just got a notification via email for your reply!
I don’t think I ever ended up implementing a solution for this, so I’ll give this a crack!
It works very well. Thank you!
I’ve been trying for a long time to figure out how to control the setpoint temperature of my TP via Sensibo and HA. We can control a lot of things, but not the setpoint temperature.
