I have 2 thermostats in my home and they are both recognised by home assistant because I can set up the temperature of one or the other in the lovelace UI.
If I use the developper tools, when I set the temperature for one or the other, it works fine.
Now I would like that when I set manually and physically on the device the temperature that the other sets itself to the same temperature.
I don’t really understand how to set the temperature on the thermostat to the value that is coming from the other thermostat.
The easiest way is to make one thermostat dominant and one thermostat subservient. What I mean by that is you can control one thermostat with a schedule (dominant) and the other thermostat with an automation.
Thanks for the reply. No, doesnt make much sense, sorry. I want to controll one or the other to set the temperature, but I think there is no way to say: if temp changed on x, this will be the master, and y is slave and do the same. A pitty
I mean, your automation works, but only if I raise the Temp from 19° to 20° for example. But If I want to lower the Temp on one of the thermostats, it doesnt work
If your goal is to keep two thermostats in sync then here is a way to do it.
alias: Make Main Floor Master
description: Keep two thermostats in sync
value_template: {{ state_attr('climate.main_floor', 'temperature') <> state_attr('climate.upstairs', 'temperature') }}
condition: []
- service: climate.set_temperature
temperature: '{{ state_attr(''climate.main_floor'', ''temperature'') }}'
entity_id: climate.upstairs
mode: singletype or paste code here
The trigger looks to see if the two temperatures are the same. If they are not equal, set the upstairs to the main floor temperature. This makes the main floor the dominant thermostat. If you only want this from say 18:00 to 22:00 in the evening, you can add that to the condition.
I have not run the automation through debug, so there could be typo’s
Not even with a time-delay or something like that? I mean, the trigger is the manual change of the target-temp, is it possible to use that info as indicator to become master?
