quintz
(Quirin Lippl)
January 24, 2023, 1:50pm
1
Hi Folks,
I’ve searched a lot about this topic but I couldn’t find anything that suits me needs.
I created a template cover for my garage door.
My Shelly Plus One is attached to my Somfy Garage Motor with a sensor that tracks the open and close status of the garage door.
My template:
covers:
garage_door:
device_class: garage
friendly_name: "Garage-Test"
unique_id: "GaragentorEichenweg-Test"
value_template: "{{ states('sensor.garagentor_zustand') }}"
open_cover:
- condition: state
entity_id: sensor.garagentor_zustand
state: "Geschlossen"
- service: switch.toggle
entity_id: switch.garagentor
close_cover:
- condition: state
state: "Offen"
stop_cover:
- condition: state
state: "Öffnet"
icon_template: >-
{% if states('sensor.garagentor_zustand', 'off') %}
mdi:garage-lock
{% else %}
mdi:garage-open
{% endif %}
My sensor. garagentor_zustand is configured like this:
- sensor:
- name: "Garagentor-Zustand"
unique_id: "Garagentorzustand"
state: >
{% if is_state('binary_sensor.garagentor_input', 'on') %}
Offen
{% elif (is_state('binary_sensor.garagentor_input', 'on') and (states.garagentor_input.last_changed < (now() - timedelta(seconds=29)))) %}
Öffnet
{% elif (is_state('binary_sensor.garagentor_input', 'on') and (switch.garagentor.last_pressed < (now() - timedelta(seconds=29)))) %}
Gestoppt
{% else %}
Geschlossen
{% endif %}
The problem is, my state of my template cover is always open after a reboot.
I’ve read several posts about this but I cannot get my head around this…
EdwardTFN
(Edward Firmo)
January 24, 2023, 2:32pm
2
This happens due to the garagentor_input
returning unknown or unavailable during the startup. You can just make your template sensor to reflect the same…
something like this:
- sensor:
state: >
{% if states('binary_sensor.garagentor_input') in ['unknown','unavailable'] %}
{{ states('binary_sensor.garagentor_input') }}
{% elif states('switch.garagentor') in ['unknown','unavailable'] %}
{{ states('switch.garagentor') }}
{% elif is_state('binary_sensor.garagentor_input', 'on') %}
Offen
Öffnet
Gestoppt
{% else %}
Geschlossen
{% endif %}
quintz
(Quirin Lippl)
January 26, 2023, 12:54pm
3
Hi Edward,
thanks for the tip - unfortunately it doesn’t work…
Got this error at boot:
Logger: homeassistant.config
Source: config.py:867
First occurred: 13:52:59 (1 occurrences)
Last logged: 13:52:59
Invalid config for [template]: invalid template (TemplateSyntaxError: unexpected ‘}’, expected ‘)’) for dictionary value @ data[‘sensor’][0][‘state’]. Got "{% if is_state(‘binary_sensor.garagentor_input’, [‘unknown’,‘unavailable’]) %} {{ states(‘binary_sensor.garagentor_input’) }} {% elif states(‘switch.garagentor’, [‘unknown’,‘unavailable’]) %} {{ states(‘switch.garagentor’) }} {% elif is_state(‘binary_sensor.garagentor_input’, ‘on’) %} Offen {% elif (is_state(‘binary_sensor.garagentor_input’, ‘on’) and (states.binary_sensor.garagentor_input.last_changed < (now() - timedelta(seconds=29))) %} Öffnet {% elif (is_state('binary_sensor.gara… (See /config/configuration.yaml, line 141).
My conf looks like this now:
- sensor:
state: >
{% if is_state('binary_sensor.garagentor_input', ['unknown','unavailable']) %}
{% elif states('switch.garagentor', ['unknown','unavailable']) %}
Offen
{% elif (is_state('binary_sensor.garagentor_input', 'on') and (states.binary_sensor.garagentor_input.last_changed < (now() - timedelta(seconds=29))) %}
Öffnet
{% elif (is_state('binary_sensor.garagentor_input', 'on') and (states.switch.garagentor.last_pressed < (now() - timedelta(seconds=29)))) %}
Gestoppt
{% else %}
Geschlossen
{% endif %}
EdwardTFN
(Edward Firmo)
January 26, 2023, 7:07pm
4
This is not valid.
Which error you have if you use exactly the code I’ve shared to you?
quintz
(Quirin Lippl)
January 27, 2023, 4:38am
5
Oh I thought this approach was correct as I read through the docu and found this formation…
I get this error when using your version:
First occurred: 05:37:36 (1 occurrences)
Last logged: 05:37:36
Invalid config for [template]: invalid template (TemplateSyntaxError: unexpected ‘}’, expected ‘)’) for dictionary value @ data[‘sensor’][0][‘state’]. Got "{% if states(‘binary_sensor.garagentor_input’) in [‘unknown’,‘unavailable’] %}\n {{ states(‘binary_sensor.garagentor_input’) }}\n{% elif states(‘switch.garagentor’) in [‘unknown’,‘unavailable’] %}\n {{ states(‘switch.garagentor’) }} \n{% elif is_state(‘binary_sensor.garagentor_input’, ‘on’) %} Offen {% elif (is_state(‘binary_sensor.garagentor_input’, ‘on’) and (states.binary_sensor.garagentor_input.last_changed < (now() - timedelta(seconds=29))) %} Öffnet {% elif (is_state('binary_sen… (See /config/configuration.yaml, line 141).
EdwardTFN
(Edward Firmo)
January 27, 2023, 7:59am
6
Are you sure you are not missing something when copying? I’ve used that code as it is and didn’t got any error message in my logs.
By the way, I was looking in yours elif
conditions and those for Öffnet
and Gestoppt
will never happens as they need the garagentor_input
to be on
and, when that is the case, it will always return Offen
EdwardTFN:
Offen
Öffnet
Gestoppt
You can move the Offen
to after Öffnet
and Gestoppt
, then it will make more sense.
quintz
(Quirin Lippl)
January 29, 2023, 9:25am
7
I just recopied your code and made the adjustments for the if states but I still get the same error…weird
EdwardTFN
(Edward Firmo)
January 29, 2023, 9:38am
8
And what is the state of binary_sensor.garagentor_input
EdwardTFN
(Edward Firmo)
January 29, 2023, 9:48am
9
I think I finally got what is the problem you have…
Try this (with the values in English and lowercase):
- sensor:
state: >
opening
stopped
open
{% else %}
closed
{% endif %}
please fix my translations properly
States of standard entities are always in English. The translations are done in the front end.
You will have to change the tests in your cover template to English too.
EdwardTFN
(Edward Firmo)
January 29, 2023, 10:00am
10
I don’t understood how your cover works… You always use switch.toggle…
Do you have a different reaction to your switch turning on or off based on the garage door state?
If you really have to toggle all the time, you should be using if…then… for this, no?
Anyways, let’s focus ou find out the initial state first, as this is the issue you asked for help here.
