I have a Insteon thermostat that has the following attributes:
hvac_modes: off, heat, cool, heat_cool
min_temp: 45
max_temp: 95
min_humidity: 1
max_humidity: 99
fan_modes: auto, fan_only
current_temperature: 78
temperature: null
target_temp_high: 78
target_temp_low: 69
current_humidity: 36
humidity: 60
fan_mode: auto
hvac_action: cooling
insteon_address: xx.xx.xx
insteon_group: 1
humidifier: off
friendly_name: Thermostat
supported_features: 15
From node red, I want to set the heat and cool setpoints (target_temp_high/low). Any ideas?
BTW, the manual for starting with homeassistant should start with nodered. Much more easy to do things than homeassistant.
