I’m trying to figure out the easiest and simplest way to have temperature A at sunset, and then temperature B at sunrise. These values do not need to change once set. Is there a way to do this ? I was hoping I could use an automation from the GUI, but I do not see any of the thermostat’s entities (like temperature) available.
I’m sort of new to Home Assistant so I appreciate the help.
Thank you. That code helped me understand that the Action wasn’t supposed to be doing something with a device, but to rather call a service. After that, it was simple to follow.
I really appreciate your response and help @Kdem. I had been struggling with this for a few days, but now have it working perfectly.
