liminal
(Shane)
1
Hey all,
Nether “white” or “white_value” seem to do anything and cant see anything under dev tools either?
How can I see the expanded list?
effect_list: None, Breathing Red
supported_color_modes: rgbw
color_mode: rgbw
brightness: 3
hs_color: 0, 67.059
rgb_color: 255, 84, 84
rgbw_color: 255, 0, 0, 125
xy_color: 0.611, 0.306
effect: Breathing Red
friendly_name: Printer Lamp
supported_features: 44
I use white: 255 to set it to max white brightness on one of my lights but another is different and I use rgbw_color: [0,0,0,255]
liminal
(Shane)
3
Thanks mate,
Its ESP home, I actually want to only set “white” to about 10%. But I cant seem to set this anywhere, only though the GUI
(using Node Red)
EDIT1
Ok, so if I add it to an automation and check the YAML
I get this value
white: 10
But if I try to set that in NR
{“white”:10}
Does nothing
Is this a bug?
Don’t forget that 100% is white: 255, so 10% will be white: 25. Using a value of 10 probably won’t even turn the light on.
I don’t use node red so can’t help on the syntax for that
liminal
(Shane)
5
Ahh, ive got ya.
That would work actually. But Ive got the syntax wrong and sadly the “Load Example Data” seems to be broken.
Anyway, Ill see what I can figure out.
Thanks again
liminal
(Shane)
6
You’re a champ!
Thanks mate, worked like this
{“rgbw_color”:[255,0,0,70]}
