Sets a climate entity to a specifc temperature at a set time everyday. If climate entity is off, it is normally not accepting temperature updated. This blueprints checks if climate entity is off and the temperature update will be set when thermostat is going back in heating mode.
This is exactly what I was looking for. Could you possibly allow the temp range to be appropriate for Fahrenheit as I am in the states? Thanks!
Yes please Fahrenheit
Hi, unfortenately I switched back to node red. Much more comfortable debugging and faster results.
Thanks for this function.
It works as long as my hass:thermostat card is in “heat” mode.
After approx. 7 min the mode is switched by “something” to “automatic” mode.
Than the " dirkk1980/set_climate_on_time.yaml" can not switch the thermostat, neither on nor off.
How to fix the the card in “heat” mode resp. an other work around.
Thanks for support…
looks like the original git link is gone, anyone still have this blueprint?
The original version was set up to do some more complicated stuff (checking heat mode). This looks like it’s working for me but might not work for everyone. All it does is blindly set the temperature in F.
blueprint:
name: Set thermostat temperature at specific time
description: Sets a climate entity to a specifc temperature at a set time every day.
domain: automation
source_url: https://www.google.com
input:
time_to_set:
description: When should the temperature be set
selector:
time:
climate_entity:
description: Climate entity which will get the temperature update
selector:
entity:
domain: climate
temp_to_set:
description: Temperature to set on defined time
default: 81
selector:
number:
min: 75
max: 88
unit_of_measurement: degrees
step: 0.5
- platform: time
at: !input time_to_set
mode: queued
- service: climate.set_temperature
entity_id: !input climate_entity
temperature: !input temp_to_set
