Set thermostat temperature possible?
Hello
I have the following thermostat setup to control my central heating boiler …
climate:
  - platform: generic_thermostat
    unique_id: central heating thermostat
    heater: switch.central_heating_switch_switch
    target_sensor: sensor.outside_sensor_side_lounge_temperature
    cold_tolerance: 0.0
    hot_tolerance: 0.3
    max_temp: 25
    min_temp: 15
Looking for help in setting up an automation so that when i say “ok nabu set the heating to 22 degrees” it will change the entity “switch.central_heating_switch_switch” to this value
Is it possible?
There are sentences and intents for setting temperature of a climate entity, but they haven’t been added to the default set of built-in intents. I don’t know why they aren’t included yet.
You can accomplish what you want using an automation with a Sentence trigger.
alias: Sentence - Set Heating
description: ""
triggers:
  - trigger: conversation
    command:
        [set | change | adjust] [temperature | heating] to {temp_value}
        [degrees]
conditions: []
actions:
  - action: climate.set_temperature
      entity_id: climate.central_heating
      temperature: "{{trigger.slots.temp_value | float(40) }}"
      hvac_mode: heat
mode: single
Thank you digeridrew, just what i was looking for :smiley:
newbie to HA yaml stuff, much appreciated
Thanks a lot!! I used your Yaml and created several automations for my smart thermostat knobs. :facepunch:
Now they are controlled by voice!
