Hello HA community.
I am an absolute newbie here and I am trying to figure out how does everything work.
This specific issue, I am struggling with, is related to default dashboard setup. I was trying to follow this guide Multiple Dashboards - Home Assistant (home-assistant.io)
about default dashboard setup, where it is saying that I need to move all my ui-lovelace.yaml contents into new .yaml that is created in Config folder.
The thing is:
I have installed the Lovelace dashboard from hacs and I see it in the ui_lovelace_minimalist/dashboard folder and it is running perfectly there
So according to the guide I need, basically, to move this ui-lovelace.yaml file (and I believe the views and popup related folders as well) in the Config folder root.
My thought was that the âxxx-cardsâ canât find the path to the .js files therefore it doesnât appear in the view. However, I tried all different paths and moving the folder with custom-cards in different places but still the same. Also, a bit confused about path:0 line showing error in ui-lovelace.yaml
Can somebody please explain me what exactly am I missingâŚ
Is there any reason doing it âthe hard wayâ?
You just create new dashboards from the UI by going into Settings â Dashboards.
After creating them you could copy raw data or individual cards.
Then, per user/device you select the default dashboard for that situation.
BTW: your post is in âShare your Projectsâ which is not the right category for this.
