I have a virgin media superhub here in the UK. I did some googling and found that a component from Switzerland seemed to work with the VM hub in ireland, so took a punt and thought it’d work for me.
I’ve added the following under config: in my configuration.yaml file.
I have also created a new file called “known_devices.yaml” and added the following for my iphone:
kinteshs_iphone:
mac: SE:CR:ET:XX:XX
track: yes
hide_if_away: no
However, my device currently shows as away.
I have two questions.
How do I know my virgin media device tracking is working?
Do I even need to do any of this? Should I just install the home assistant app instead? If so, how does location tracking work from that and do I need ‘known_devices.yaml’ if I do it this way?
Recommend to go for the iphone app. Iphones disconnect from the router when in sleep mode so the router based presence detection is not recommended for iphone
Final question I guess - I just installed the iphone app, but I’m not quite sure how to get homeassistant to know if I’m home/not home. Does this happen automatically?
