Set up ESP32 ESPHome device to be recognized by new ESPHome Wifi network
I have an existing ESP32 device that is to be used as an operational remote through the HA Frontend. I have all of that working with 3 button toggles per button - single click, double click, hold. I am trying to set up my ESP32 device to somehow be able to be discovered by another HA/ESPHome. I have this somewhat working. My problem is updating WiFi secrets without destroying the existing YAML configurations I’ve made. Here’s my YAML:
esphome:
  friendly_name: esp32
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "j2c7Y/RdRJL2Lew5Q7IVNI8KiEqQOrWY5s0Vf8P66o8="
ota:
  - platform: esphome
    password: "4f4e3cb2f1d52bea59eda10bba1838ac"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esp32 Fallback Hotspot"
    password: "Z2kC8tfVUFym"
captive_portal:
switch:
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    name: "Volume Up Single"
    optimistic: true
    name: "Volume Up Hold"
    optimistic: true
    name: "Volume Up Double"
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    name: "Channel Up Single"
    optimistic: true
    name: "Channel Up Hold"
    optimistic: true
    name: "Channel Up Double"
    optimistic: true
    name: "Volume Down Single"
    optimistic: true
    name: "Volume Down Hold"
    optimistic: true
    name: "Volume Down Double"
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    name: "Channel Down Single"
    optimistic: true
    name: "Channel Down Hold"
    optimistic: true
    name: "Channel Down Double"
    optimistic: true
    name: "Skip Back Single"
    optimistic: true
    name: "Skip Back Hold"
    optimistic: true
    name: "Skip Back Double"
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    name: "Skip Forward Single"
    optimistic: true
    name: "Skip Forward Hold"
    optimistic: true
    name: "Skip Forward Double"
    optimistic: true
    name: "Fast Back Single"
    optimistic: true
    name: "Fast Back Hold"
    optimistic: true
    name: "Fast Back Double"
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    name: "Fast Forward Single"
    optimistic: true
    name: "Fast Forward Hold"
    optimistic: true
    name: "Fast Forward Double"
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
    optimistic: true
binary_sensor:
# needs its own pullup
  - platform: gpio
    pin:
      number: GPIO36
      inverted: false
      mode:
        input: true
        #pullup: true (gpio36 doesn't have internal pullup)
    internal: true #(this hides the plain button from HA frontend)
    on_multi_click:
      - timing:
          - ON for at most 0.5s
          - OFF for at most 0.2s
          - OFF for at least 0.2s
        then:
          - switch.toggle: menu_double
        invalid_cooldown: 0.2s
      - timing:
          - ON for at least 0.5s
        then:
          - switch.toggle: menu_hold
      - timing:
        then:
          - switch.toggle: menu_single
  - platform: gpio
    pin:
      number: GPIO39
      inverted: false
      mode:
        input: true
        #pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: up_double
      - timing:
        then:
          - switch.toggle: up_hold
      - timing:
        then:
          - switch.toggle: up_single
  - platform: gpio
    pin:
      number: GPIO2
      inverted: false
      mode:
        input: true
        #pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: power_double
      - timing:
        then:
          - switch.toggle: power_hold
      - timing:
        then:
          - switch.toggle: power_single
  - platform: gpio
    pin:
      number: GPIO35
      inverted: false
      mode:
        input: true
        #pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: left_double
      - timing:
        then:
          - switch.toggle: left_hold
      - timing:
        then:
          - switch.toggle: left_single
  - platform: gpio
    pin:
      number: GPIO33
      inverted: true
      mode:
        input: true
        pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: ok_double
      - timing:
        then:
          - switch.toggle: ok_hold
      - timing:
        then:
          - switch.toggle: ok_single
  - platform: gpio
    pin:
      number: GPIO32
      inverted: true
      mode:
        input: true
        pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: right_double
      - timing:
        then:
          - switch.toggle: right_hold
      - timing:
        then:
          - switch.toggle: right_single
  - platform: gpio
    pin:
      number: GPIO25
      inverted: true
      mode:
        input: true
        pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: vol_up_double
      - timing:
        then:
          - switch.toggle: vol_up_hold
      - timing:
        then:
          - switch.toggle: vol_up_single
  - platform: gpio
    pin:
      number: GPIO26
      inverted: true
      mode:
        input: true
        pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: down_double
      - timing:
        then:
          - switch.toggle: down_hold
      - timing:
        then:
          - switch.toggle: down_single
  - platform: gpio
    pin:
      number: GPIO27
      inverted: true
      mode:
        input: true
        pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: ch_up_double
      - timing:
        then:
          - switch.toggle: ch_up_hold
      - timing:
        then:
          - switch.toggle: ch_up_single
  - platform: gpio
    pin:
      number: GPIO14
      inverted: true
      mode:
        input: true
        pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: vol_down_double
      - timing:
        then:
          - switch.toggle: vol_down_hold
      - timing:
        then:
          - switch.toggle: vol_down_single
  - platform: gpio
    pin:
      number: GPIO12
      inverted: true
      mode:
        input: true
        pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: mute_double
      - timing:
        then:
          - switch.toggle: mute_hold
      - timing:
        then:
          - switch.toggle: mute_single
  - platform: gpio
    pin:
      number: GPIO13
      inverted: true
      mode:
        input: true
        pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: ch_down_double
      - timing:
        then:
          - switch.toggle: ch_down_hold
      - timing:
        then:
          - switch.toggle: ch_down_single
  - platform: gpio
    pin:
      number: GPIO15
      inverted: true
      mode:
        input: true
        pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: skip_back_double
      - timing:
        then:
          - switch.toggle: skip_back_hold
      - timing:
        then:
          - switch.toggle: skip_back_single
# need its own pullup
  - platform: gpio
    pin:
      number: GPIO34
      inverted: false
      mode:
        input: true
        #pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: stop_double
      - timing:
        then:
          - switch.toggle: stop_hold
      - timing:
        then:
          - switch.toggle: stop_single
  - platform: gpio
    pin:
      number: GPIO0
      inverted: true
      mode:
        input: true
        pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: skip_fwd_double
      - timing:
        then:
          - switch.toggle: skip_fwd_hold
      - timing:
        then:
          - switch.toggle: skip_fwd_single
  - platform: gpio
    pin:
      number: GPIO4
      inverted: true
      mode:
        input: true
        pullup: true
    name: "Fast Backward"
    on_multi_click:
      - timing:
        then:
          - switch.toggle: fast_back_double
      - timing:
        then:
          - switch.toggle: fast_back_hold
      - timing:
        then:
          - switch.toggle: fast_back_single
  - platform: gpio
    pin:
      number: GPIO16
      inverted: true
      mode:
        input: true
        pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: play_pause_double
      - timing:
        then:
          - switch.toggle: play_pause_hold
      - timing:
        then:
          - switch.toggle: play_pause_single
  - platform: gpio
    pin:
      number: GPIO17
      inverted: true
      mode:
        input: true
        pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: fast_fwd_double
      - timing:
        then:
          - switch.toggle: fast_fwd_hold
      - timing:
        then:
          - switch.toggle: fast_fwd_single
  - platform: gpio
    pin:
      number: GPIO5
      inverted: true
      mode:
        input: true
        pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: a_double
      - timing:
        then:
          - switch.toggle: a_hold
      - timing:
        then:
          - switch.toggle: a_single
  - platform: gpio
    pin:
      number: GPIO18
      inverted: true
      mode:
        input: true
        pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: b_double
      - timing:
        then:
          - switch.toggle: b_hold
      - timing:
        then:
          - switch.toggle: b_single
  - platform: gpio
    pin:
      number: GPIO23
      inverted: true
      mode:
        input: true
        pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: c_double
      - timing:
        then:
          - switch.toggle: c_hold
      - timing:
        then:
          - switch.toggle: c_single
  - platform: gpio
    pin:
      number: GPIO19
      inverted: true
      mode:
        input: true
        pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: d_double
      - timing:
        then:
          - switch.toggle: d_hold
      - timing:
        then:
          - switch.toggle: d_single
  - platform: gpio
    pin:
      number: GPIO21
      inverted: true
      mode:
        input: true
        pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: e_double
      - timing:
        then:
          - switch.toggle: e_hold
      - timing:
        then:
          - switch.toggle: e_single
  - platform: gpio
    pin:
      number: GPIO22
      inverted: true
      mode:
        input: true
        pullup: true
    on_multi_click:
      - timing:
        then:
          - switch.toggle: f_double
      - timing:
        then:
          - switch.toggle: f_hold
      - timing:
        then:
          - switch.toggle: f_single
In a test scenario I deleted the YAML in the ESPHome web UI and tried to establish a connection with the device. When plugged in to the HA station it was recognized, but was not recognized wirelessly. I imagine because things like the API key, OTA password, and fallback hotspot password weren’t set up. Is there a way to set this up without damaging the YAML that exists?
My end goal is to produce remotes for colleagues and have them set up their own sensitive information. If I can get that down to just updating wifi credentials that would be optimal.
I should note that I have file backups, that is not the issue. I need a way for a new user to take the esp32 remote with its existing YAML, integrate it into their system, update the WiFi information so it can be used wirelessly - all without destroying the existing YAML existing in the esp32 device.
I am not sure what you are asking.
If you take it to a friend’s place, then it won’t connect to the friends wifi. It will bring up a fallback hotspot and got can enter the friends wifi details. Profit.
That works perfectly, I can’t believe I missed that
