I’m trying o setup a simple mqtt based FAN connected to a Sonoff tasiota switch. I know I could use switch but I would like to match my objects with HA semantic.
The problem I’ve is the state detection of the FAN.
This is what I’ve from my mqtt server
stat/fan/POWER which can be ON or OFF (capital Letter)
or
stat/fan/RESULT which can be { “POWER”: “ON”} or {“POWER”: “OFF”
This is my mqtt fan
fan:
- platform: mqtt
unique_id: fan
command_topic: “cmnd/fan/power”
payload_on: “1”
payload_off: “0”
state_topic: “stat/fan/RESULT”
state_value_template: “{{value_json.POWER | lower }}”
speeds: off
retain: “false”
optimistic: false
qos: 0
I also tried with
state_topic: “stat/fan/POWER”
state_value_template: " {{value | lower }}"
with no luck.
Could somebody tell me what I’ doing wrong?
Thanks,
Raffaele.
