Finally my HA 94.4 system seems to get the version sensor alright, and setting the logger to debug reveals this in a continuous circle:
2019-07-02 06:36:27 DEBUG (MainThread) [pyhaversion] Version: 0.94.4
2019-07-02 06:36:27 DEBUG (MainThread) [pyhaversion] Version data: {'source': 'Local'}
2019-07-02 06:36:27 DEBUG (MainThread) [pyhaversion] Version: 0.95.4
2019-07-02 06:36:27 DEBUG (MainThread) [pyhaversion] Version data: {'source': 'PyPi', 'beta': False}
2019-07-02 06:37:31 DEBUG (MainThread) [pyhaversion] Version: 0.94.4
2019-07-02 06:37:31 DEBUG (MainThread) [pyhaversion] Version data: {'source': 'Local'}
2019-07-02 06:37:31 DEBUG (MainThread) [pyhaversion] Version: 0.95.4
2019-07-02 06:37:31 DEBUG (MainThread) [pyhaversion] Version data: {'source': 'PyPi', 'beta': False}
2019-07-02 06:37:44 ERROR (SyncWorker_12) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2019-07-02 06:38:36 DEBUG (MainThread) [pyhaversion] Version: 0.94.4
2019-07-02 06:38:36 DEBUG (MainThread) [pyhaversion] Version data: {'source': 'Local'}
2019-07-02 06:38:36 DEBUG (MainThread) [pyhaversion] Version: 0.95.4
2019-07-02 06:38:36 DEBUG (MainThread) [pyhaversion] Version data: {'source': 'PyPi', 'beta': False}
2019-07-02 06:39:41 DEBUG (MainThread) [pyhaversion] Version: 0.94.4
2019-07-02 06:39:41 DEBUG (MainThread) [pyhaversion] Version data: {'source': 'Local'}
2019-07-02 06:39:42 DEBUG (MainThread) [pyhaversion] Version: 0.95.4
2019-07-02 06:39:42 DEBUG (MainThread) [pyhaversion] Version data: {'source': 'PyPi', 'beta': False}
2019-07-02 06:40:46 DEBUG (MainThread) [pyhaversion] Version: 0.94.4
2019-07-02 06:40:46 DEBUG (MainThread) [pyhaversion] Version data: {'source': 'Local'}
2019-07-02 06:40:46 DEBUG (MainThread) [pyhaversion] Version: 0.95.4
2019-07-02 06:40:46 DEBUG (MainThread) [pyhaversion] Version data: {'source': 'PyPi', 'beta': False}
2019-07-02 06:41:13 DEBUG (MainThread) [pyhaversion] Version: 0.94.4
2019-07-02 06:41:13 DEBUG (MainThread) [pyhaversion] Version data: {'source': 'Local'}
2019-07-02 06:41:14 DEBUG (MainThread) [pyhaversion] Version: 0.95.4
2019-07-02 06:41:14 DEBUG (MainThread) [pyhaversion] Version data: {'source': 'Hassio', 'beta': False, 'board': 'rpi3', 'image': 'raspberrypi3', 'hassos': '2.12', 'supervisor': '167', 'hassos-cli': '9'}
as you can see the bottom line follows the setup for available as I’ve configured it:
- platform: version
name: HA installed version
- platform: version
name: HA available version
# beta: true
image: raspberrypi3
source: hassio
Any idea why it would use the other format for available as it does above on the other timings in this circle:
Secondly, could I set the scan_interval on these sensors, because scanning each and every minute is a bit much…
scan_interval: 14400
would suffice …
thanks.
