Does anyone know, how i could set the yi home cameras into away or home mode without installing the custom firmware on each device, which is needed for the home assistant integration i found?
Maybe there is an integration, which calls an api or something to set home or away mode to switch on or off camera recording depending on movement?
Thank you!
