Hello, im having a little bit trouble understanding a template. Im using this behaviour to control in which rooms the vacuum will clean. Everything works as expected, when i press one of the buttons the notification displays the correct number, the vacuum goes where i told it to etc.
The problem comes when it finishes the cleaning - I want to reset all the buttons’ states to 0 so they dont display the notification. Any idea how can I do that? The script that adds/removes rooms from the variable is this:
deebot_room_queue:
description: Add/Remove a room from the queue
fields:
queue:
description: The queue variable
example: hans_queue
room:
description: Room, which should be removed or added
example: kitchen
sequence:
- service: variable.set_variable
variable: "{{ queue }}"
value: >-
{%- set queue = states("variable.hans_queue").split(",") -%}
{%- if states("variable.hans_queue") | length == 0 -%}
{{ room }}
{%- elif room in queue -%}
{{ queue | reject("eq", room) | list | join(",")}}
{%- else -%}
{{ (queue + [room]) | join(",") }}
{%- endif -%}
Rather than trying to change anything here, could you have a separate automation that monitors the vacuum’s state and clears the list when it is done cleaning?
in your example and on the linked sites i only see all buttons set to 0 when HA restarts.
Edit: and of course with the posted script, when you press the card from UI
template:
unique_id: deebot_susi_queue
- platform: homeassistant
event: start
- platform: state
entity_id: variable.deebot_susi_queue
# Add for each room the following. Change "living_room" accordingly
- unique_id: deebot_susi_queue_living_room
state: >
{% set queue = trigger.to_state.state.split(",") if trigger.to_state is defined else "" %}
{{ queue.index('living_room')+1 if 'living_room' in queue else 0 }}
queue is then " "
and the room 0
does your vacuum have a sensor exposed in HA that reports in some kind when he finished his job like deebot here Entities - DeebotUniverse when the state reports that he finished?
you could then try to set an additional trigger like this (below is just an expample how it could look like)
template:
event: start
- platform: state
- platform: state
entity_id: sensor.last_cleaning_job
to: "finished"
and here is the script in which I can’t figure out what to do
clear_room_queue:
description: Resets all the rooms that have been put into the cleaning queue
sequence:
variable: variable.hans_queue
value: >
{{ 0 }}
ok i think setting the value to “” should work and you only have to set the variable name in the service call, not the entity.
clear_room_queue:
sequence:
variable: hans_queue
value: ""
