Sets daytime mode depending on time and day off
This blueprint sets an input_select containing different daytime modes depending on set times. The state of the input_select could be used as a trigger for a variety of events. As an example, I use the state of the input_select to call different light profiles over the day (Turn on a light with different light profile).
The time for “wake up” and “morning” mode could be defined individually if today is a day off or not.
A time for “bedtime” mode could be defined, if tomorrow is not a day off.
Requirements for this blueprints are:
A input_select, containing the following(“Nightmode” is not obligatory):
input_select.yaml
daytimemode:
options:
- Wakeup
- Morning
- Lunchtime
- Afternoon
- Evening
- Bedtime
- Nightmode
initial: Wakeup
and two binary sensors. One for day off today and one fore day off tomorrow.
blueprint:
  name: Change daytime mode
  description: "This Blueprint changes the state of a Input_select depending on the time of the day and of today ore tomorrow ist a day off. "
  domain: automation
  input:
    dayzykle:
      description: "This must be an input_select with the variaty of dayzykle. The input_select must contains minimum following selectors: Wakeup, Morning, Lunchtime, Afternoon, Evening, Bedtime."
      selector:
        entity:
          domain: input_select
    day_off_today:
      name: "day off today"
      description: "Boolan sensor if today is a day off."
      selector:
        entity:
          domain: binary_sensor
    day_off_tomorrow:
      name: "day off tomorrow"
      description: "Boolan sensor if tomorrow is a day off."
      selector:
        entity:
    wakeup:
      description: "Time when changing the input_select to Wakeup mode!"
      selector:
        time:
    wakeup_day_off:
      name: "Wakeup time day off"
      description: "Time when changing the input_select to Wakeup mode on day off!"
      selector:
        time:
    morning:
      description: "Time when changing the input_select to Morning mode!"
      selector:
        time:
    morning_day_off:
      name: "Morning time day off"
      description: "Time when changing the input_select to Morning mode on day off!"
      selector:
        time:
    lunchtime:
      description: "Time when changing the input_select to lunchtime mode!"
      selector:
        time:
    afternoon:
      description: "Time when changing the input_select to afternoon mode!"
      selector:
        time:
    evening:
      description: "Time when changing the input_select to evening mode!"
      selector:
        time:
    bedtime_no_day_off_tomorrow:
      description: "Time when changing the input_select to bedtime mode when tomorre is no day off!"
      selector:
        time:
mode: restart
  - platform: time
    at: !input wakeup # trigger 0
  - platform: time
    at: !input wakeup_day_off # trigger 1
  - platform: time
    at: !input morning # trigger 2
  - platform: time
    at: !input morning_day_off # trigger 3
  - platform: time
    at: !input lunchtime # trigger 4
  - platform: time
    at: !input afternoon # trigger 5
  - platform: time
    at: !input evening # trigger 6
  - platform: time
    at: !input bedtime_no_day_off_tomorrow # trigger 7
  - platform: homeassistant # trigger 8
    event: start
  - variables:
      trigger_id: "{{ trigger.id }}"
  - choose:
      #wakeup no day off
      - conditions:
          - condition: and
            conditions:
              - condition: template
                value_template: >
                  {{ trigger_id == 0 }}
              - condition: state
                entity_id: !input day_off_today
                state: "off"
        sequence:
          - service: input_select.select_option
              entity_id: !input "dayzykle"
              option: Wakeup
      #wakeup day off
      - conditions:
          - condition: and
            conditions:
                value_template: >
                  {{ trigger_id == 1 }}
              - condition: state
                state: "on"
        sequence:
              option: Wakeup
      #Morning no day off
      - conditions:
          - condition: and
            conditions:
                value_template: >
                  {{ trigger_id == 2 }}
              - condition: state
                state: "off"
        sequence:
              option: Morning
      #Morning day off
      - conditions:
          - condition: and
            conditions:
                value_template: >
                  {{ trigger_id == 3 }}
              - condition: state
                state: "on"
        sequence:
              option: Morning
      #Lunchtime
      - conditions:
          condition: template
          value_template: >
            {{ trigger_id == 4 }}
        sequence:
              option: Lunchtime
      #Afternoon
      - conditions:
          condition: template
          value_template: >
            {{ trigger_id == 5 }}
        sequence:
              option: "Afternoon"
      #Evening
      - conditions:
          condition: template
          value_template: >
            {{ trigger_id == 6 }}
        sequence:
              option: "Evening"
      #bedtime no day off tomorrow
      - conditions:
          - condition: and
            conditions:
                value_template: >
                  {{ trigger_id == 7 }}
              - condition: state
                entity_id: !input day_off_tomorrow
                state: "off"
        sequence:
              option: Bedtime
      #on reboot server#wakeup no day off
      - conditions:
          - condition: and
            conditions:
                value_template: >
                  {{ trigger_id == 8 }}
              - condition: state
                state: "off"
              - condition: time
                after: !input wakeup
                before: !input morning
        sequence:
              option: Wakeup
      #on reboot server#wakeup day off
      - conditions:
          - condition: and
            conditions:
                value_template: >
              - condition: state
                state: "on"
              - condition: time
                after: !input wakeup_day_off
                before: !input morning_day_off
        sequence:
              option: Wakeup
      #on server start#Morning no day off
      - conditions:
          - condition: and
            conditions:
                value_template: >
              - condition: state
                state: "off"
              - condition: time
                after: !input morning
                before: !input lunchtime
        sequence:
              option: Morning
      #on server start#Morning day off
      - conditions:
          - condition: and
            conditions:
                value_template: >
              - condition: state
                state: "on"
              - condition: time
                after: !input morning_day_off
        sequence:
              option: Morning
      #on server start#Lunchtime
      - conditions:
          - condition: and
            conditions:
                value_template: >
              - condition: time
                after: !input lunchtime
                before: !input afternoon
        sequence:
              option: Lunchtime
      #on server start#Afternoon
      - conditions:
          - condition: and
            conditions:
                value_template: >
              - condition: time
                after: !input afternoon
                before: !input evening
        sequence:
              option: "Afternoon"
      #on server start#Evening no day off tomorrow
      - conditions:
          - condition: and
            conditions:
                value_template: >
              - condition: state
                state: "off"
              - condition: time
                after: !input evening
                before: !input bedtime_no_day_off_tomorrow
        sequence:
              option: "Evening"
      #on server start#Evening day off tomorrow
      - conditions:
          - condition: and
            conditions:
                value_template: >
              - condition: state
                state: "on"
              - condition: time
        sequence:
              option: "Evening"
      #on server start#bedtime no day off tomorrow
      - conditions:
          - condition: and
            conditions:
                value_template: >
              - condition: state
                state: "off"
              - condition: time
                after: !input bedtime_no_day_off_tomorrow
        sequence:
              option: Bedtime
Hi!
Would love to use your blueprint, but I am still figuring things out in Home Assistant. Got the input_select working, but can't figure out how to set up the binary sensors. Would you be willing to elaborate how to do this?
Hi elvee,
basically I use the work day integration to generate those binary sensors.
To spice everthing up I use the caldav integration and combine those Binary sensors using a template sensor. But every other calender integration should work as well.
my template sensor looks like this
 binary_sensor:
  - name: "day off today"
    unique_id: "day off today"
    state: >
      {{ is_state('calendar.workcalender_vacation_today', 'on')
        or is_state('binary_sensor.weekend', 'on')
        or is_state('binary_sensor.holidays', 'on') }}
  - name: "day off tomorrow"
    unique_id: "day off tomorrow"
    state: >
      {{ is_state('binary_sensor.workcalender_vacation_tomorrow', 'on')
        or is_state('binary_sensor.weekend_tomorrow', 'on')
        or is_state('binary_sensor.holidays_tomorrow', 'on') }}
Thanks a lot for your reply. Should be able to get this working now.
I used different time of day states in my former home automation setup.
Your blueprint is a very big advantage to use time of day based automations.
Thanks!!!
thanks for this blueprint but, if i would use the last selector nightmode how i can implement it into your blueprint?
Hi. I trigger the nightmode by an extra automatisation. You have to ad a Trigger and a related condition and an Input to the blueprint.
Sorry for the late and short answer. I currently dont have much time.
BR
