Setting a background image
I need a step by step.
I got a .jpg picture uploaded to my /config folder but also next to my lovelace.yaml file (same image, same name).
I’ve tried a lot of things with this command but I can’t get it to work. I have dark ios theme installed now.
background: center / cover no-repeat fixed url('picture.jpg')
You need to create a config/www folder, put your image in there, adjust your picture URL to ‘local/picture.jpg’ and restart.
In the raw config or somewhere in the ios-dark-theme.yaml?
Still having trouble with this… It does appear sometimes… any good guides out there?
Nobody? I’ve edited the dark-ios.yaml with /local/picture.jpg and put the picture in /config/www/picture.jpg.
Also in the raw-formatting I’ve tried the same thing…
Until recently this worked but after the last Home Assistant update it stopped. Does anyone know how it can be solved?
bump
ive spent hours on this and im unable to set a background too.
im running the latest ha
this is what ive got in my config
frontend:
  themes:
    my_theme: # call it whatever you want
      background: center / cover no-repeat fixed url('/local/images/pic.jpg')
when I set a theme on the dashboard it comes up with “my theme” but selecting it does not change the background.
OK, I’m running into a similar issue. All I want to do is have a single background image that is common to the system (i.e. for all the dashboards).
  1. Downloaded a hi-res (7.7MB) image of the Milky Way. Put it in a folder under www called images. The file is named MilkyWay.jpg
  2. In the Themes folder, created another folder named MilkyWay, and under that have a YAML file called MilkyWay.yaml
  3. Contents of yaml file are:
    MilkyWay:
    background: center / cover no-repeat fixed url(’/local/images/MilkyWay.jpg’)
After a reboot, I can select MilkWay as a theme, but sadly, the image is not displayed - I just get a regular white background :frowning:
is this process properly documented anywhere?
Or (even better), is there a way to achieve this without using a theme. It strikes me that this should be a really simple thing to achieve.
try lovelace-background: 'center / cover no-repeat url("/local/pic-name.jpg") fixed'
This is what I’m using in my autumn.yaml file
autumn-leafs:
  # Background image
  lovelace-background: 'center / cover no-repeat url("/local/autumn.jpg") fixed'
