Setting a condition using an entity's history
I would like to use rain data as a condition for automating a watering valve. The entity I would like to use is “daily rain”. I want to have an automation that turns on the watering valve unless the value of “daily rain” over 2 or 3 days exceeds a specified amount (eg 1). Is there a way to use the history of “daily rain” to do this?
Can’t help with your exact problem, but have you taken a look at these irrigation integrations, especially this one:
Good idea. I’ll look at your link and check out some others.
You can define a new entity based on your rain entity using the statistics integration:
Maybe you can help me with my sensor setup. I am receiving an error when I check configuration.yaml.
Invalid config for [sensor]: required key not provided @ data[‘platform’]. Got None. (See /home/homeassistant/homeassistant/configuration.yaml, line 47).
Line 47 is “sensor:”.
  -platform: statistics
   name:"Two day rain total"
   entity_id:sensor.meteobridge_precipitation_today
   state_characteristic:total
   sampling_size:2
Wrong indentation and/or whitespace between platform and hyphen:
- platform: statistics <= whitespace between
Can’t say if the lines beneath have to be indented more or less, but try it first with the extra whitespace between the hyphen and the platform.
That did it. Thanks!
