If I understood you correctly these are some examples that should help you. The third example uses node-red-contrib-throttle. Also returning null in a function node stops the flows.
[{"id":"bebcf877.bbab18","type":"server-state-changed","z":"5eb3594f.d294b8","name":"Sensor","server":"ef067c6f.620e6","entityidfilter":"sensor.sensor","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"x":114,"y":1936,"wires":[["27fa6116.c414de"]]},{"id":"1d94a1e8.c558de","type":"debug","z":"5eb3594f.d294b8","name":"Notify People","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":742,"y":1968,"wires":[]},{"id":"27fa6116.c414de","type":"switch","z":"5eb3594f.d294b8","name":"In Range?","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"50","vt":"num","v2":"75","v2t":"num"},{"t":"else"}],"checkall":"false","repair":false,"outputs":2,"x":262,"y":1936,"wires":[["458ca65f.ce00d8"],["378c1d7b.991e32"]]},{"id":"458ca65f.ce00d8","type":"change","z":"5eb3594f.d294b8","name":"Reset Throttle","rules":[{"t":"set","p":"notifyThrottled","pt":"flow","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":448,"y":1920,"wires":[[]]},{"id":"378c1d7b.991e32","type":"switch","z":"5eb3594f.d294b8","name":"Throttled?","property":"notifyThrottled","propertyType":"flow","rules":[{"t":"false"}],"checkall":"true","repair":false,"outputs":1,"x":428,"y":1968,"wires":[["2c5e930c.69cfac"]]},{"id":"2c5e930c.69cfac","type":"change","z":"5eb3594f.d294b8","name":"Set Throttled","rules":[{"t":"set","p":"notifyThrottled","pt":"flow","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":582,"y":1968,"wires":[["1d94a1e8.c558de"]]}]
![](https://community-assets.home-assistant.io/original/3X/1/3/13d49c228564369f49f50646ef78ee5bf6c21721.png)
[{"id":"e40b0977.a4a4e8","type":"server-state-changed","z":"5eb3594f.d294b8","name":"Sensor","server":"ef067c6f.620e6","entityidfilter":"sensor.sensor","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"x":130,"y":2048,"wires":[["bd29dc40.0a9de"]]},{"id":"b12cf332.1ec1b","type":"debug","z":"5eb3594f.d294b8","name":"Notify People","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":406,"y":2048,"wires":[]},{"id":"bd29dc40.0a9de","type":"function","z":"5eb3594f.d294b8","name":"logic","func":"const throttled = context.get('throttled') || false;\nif (msg.payload > 50 && msg.payload < 75) {\n context.set('allow', false);\n return null;\n}\n\nif (throttled) return null;\n\ncontext.set('throttled', true);\n\nreturn msg;","outputs":1,"noerr":0,"x":258,"y":2048,"wires":[["b12cf332.1ec1b"]]}]
[{"id":"a32dcae7.adb568","type":"server-state-changed","z":"5eb3594f.d294b8","name":"Sensor","server":"ef067c6f.620e6","entityidfilter":"sensor.sensor","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"x":114,"y":2160,"wires":[["cd1189e4.a85718"]]},{"id":"dcaba920.bf92d8","type":"debug","z":"5eb3594f.d294b8","name":"Notify People","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":710,"y":2160,"wires":[]},{"id":"e3808b38.2a2d88","type":"throttle","z":"5eb3594f.d294b8","name":"","throttleType":"reset","timeLimit":0,"timeLimitType":"seconds","countLimit":0,"blockSize":0,"locked":true,"x":562,"y":2160,"wires":[["dcaba920.bf92d8"]]},{"id":"cd1189e4.a85718","type":"switch","z":"5eb3594f.d294b8","name":"In Range?","property":"payload","propertyType":"msg","rules":[{"t":"btwn","v":"50","vt":"num","v2":"75","v2t":"num"},{"t":"else"}],"checkall":"false","repair":false,"outputs":2,"x":262,"y":2160,"wires":[["a78ed7db.0697e8"],["e3808b38.2a2d88"]]},{"id":"a78ed7db.0697e8","type":"change","z":"5eb3594f.d294b8","name":"reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":418,"y":2112,"wires":[["e3808b38.2a2d88"]]}]
