I’m very new to Node-RED, so this should probably be categorised as a noob question…But, here goes.
I have a flow that consists of the following
- A events:state node, that reads an input_boolean and is connected to a…
- Switch node, that has 2 outputs, “on” and “off” (based on the input_boolean). “On” is connected to a…
- “call service” node. This node sets another HA entity (an input_number) to a fixed value, “18”. I’ve entered the following
"value": "18"
in the “data” field (I guess you can call this a payload".
So, when the state node is set to “on”, the input_number is set to 18. I have tested the flow, and it works.
But, how can I replace the static value (“18”) with yet another value from HA, in this case, a sensor? I’ve tried “everything”, but can’t get my head around how this works.
I.e., i want to replace the JSON above with
"value": [states.sensor.xxx]
(The problem that I want to solve is the following: When I enable “vacation mode” in HA, I want to set my heat pump to a preconfigured value. I know that this could be done with a basic HA automation, but this is going to be a more complex flow later on, I’m just trying to understand the basics now).
