I want to control 4 relays with input select options; off,1,2,3,4 and only 1 relay can be active at once.
I can do this with mqtt and esp8266, but cant figure out how to read the actual state over mqtt and set the input select option accordingly
configurator
- platform: mqtt
state_topic: “/ESP/gpio/12”
command_topic: “/ESP/gpio/12”
payload_on: “0”
payload_off: “1” - platform: mqtt
state_topic: “/ESP/gpio/13”
command_topic: “/ESP/gpio/13”
payload_on: “0”
state_topic: “/ESP/gpio/14”
command_topic: “/ESP/gpio/14”
payload_on: “0”
state_topic: “/ESP/gpio/16”
command_topic: “/ESP/gpio/16”
payload_on: “0”
payload_off: “1”
automation
alias: Huippuimuri pois päältä
platform: state
entity_id: input_select.huippuimuri
to: “OFF”
action:- service: switch.turn_off
entity_id:- group.huippuimurin_nopeus
alias: Huippuimuri nopeus 1
trigger:- platform: state
to: “1”
action: - service: switch.turn_off
- service: switch.turn_on
entity_id:- switch.huippuimuri1
- platform: state
alias: Huippuimuri nopeus 2
platform: state
to: “2”
entity_id:- switch.huippuimuri2
alias: Huippuimuri nopeus 3
platform: state
to: “3”
entity_id:- switch.huippuimuri3
alias: Huippuimuri nopeus 4
platform: state
to: “4”
entity_id:- switch.huippuimuri4
They are made to group and set all relays off before setting only one on. This works fine, but with more automation the input select will eventually lose track of what switch is actually active…
