Setting binary light status
We have old home automation system in our house. It is using CAN bus.
I can read bus, and set light states as binary sensors.
like this:
binary_sensor:
Then i have this in lambda for canbus:
if(x[0]==0x06 and x[1]==0x31 and x[2]==0x61) {
  id(tyohuone_led).publish_state(x[3]);
This works fine, and HA sees light state.
I would like to use binary_light and not binary sensor, so i could also control lights from home assistant.
How can i set only state of light change in esphome without triggering any actions (when light state is physically changed)? Only when HA is changing state should esphome send light on/off state change to CAN bus to actually turn light on/off.
Something like this to turn light on
on_...:
  - canbus.send:
      data: [ 0x06, 0x30, 0x61, 0x01 ]
      can_id: 0x18efff21
You could also redefine the binary as a light.
Define a template output with the lambda you already have Template Output — ESPHome
Set up a binary light linked to that output Binary Light — ESPHome
I am new to this, and really do not know what i should change. I have done simple temperature etc sensor before, but this is my first bigger project.
This is my code, and it works as it should. I can see states of lights, motion sensors and temperatures in home assistant just fine.
What should i change to control lights from HA?
When physical light switch is pushed input module sends to can bus (tyohuone_led)
0x06 0x30 0x61 0x01 for light on
0x06 0x30 0x61 0x00 for light off
Then output module turns light on/off and responds to can bus (tyohuone_led)
0x06 0x31 0x61 0x01 for light on
0x06 0x31 0x61 0x00 for light off
I now monitor can bus for output module responses and change binary sensor.
What should i change to use light entity instead binary sensor?
Light state should be changed same as in now. When HA changes state, should esphome send input module on/off command to can bus.
If physical button is pressed, and output module sends response, light state should be changed, but nothing should be send to can bus (light is already controlled by output module of automation system).
esphome:
  friendly_name: Talomat
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
  logs:
    component: ERROR
    canbus: ERROR
# Enable Home Assistant API
api:
  encryption:
    key: "keykeykey"
ota:
  password: "passwordpassword"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Talomat Fallback Hotspot"
web_server:
 port: 80
captive_portal:
    device_class: "temperature"
    state_class: "measurement"
    accuracy_decimals: 0
    name: "Ulko valoisuus raw"
    accuracy_decimals: 1
    filters:
      - throttle_average: 30s
      - filter_out: nan
binary_sensor:
    name: "MH Anton led"
    name: "MH Anton kansi"
    name: "MH Joonas led"
    name: "MH Joonas kansi"
    name: "Yläkerta vessa led"
    name: "Alakerta vessa led"
    name: "Liiketunnistin yläkerta"
    filters:
      - delayed_off: 10s
    filters:
      - delayed_off: 10s
    name: "Liiketunnistin kodinhoitohuone"
    filters:
      - delayed_off: 10s
    name: "Liiketunnistin etuterassi"
    filters:
      - delayed_off: 10s
    name: "Liiketunnistin autokatos"
    filters:
      - delayed_off: 10s
    name: "Liiketunnistin takaterassi"
    filters:
      - delayed_off: 10s
    name: "MH Pää kansi"
    name: "MH Pää led"
    name: "Keittiö allas led"
    name: "Keittiö uuni led"
    name: "Keittiö porras led"
    name: "Kodinhoitohuone allas led"
    name: "Tekninen tila kansi"
    name: "Olohuone takaoikea led"
    name: "Olohuone takavasen led"
    name: "Olohuone takka led"
    name: "Eteinen WC led"
    name: "Eteinen vaatekaappi led"
    name: "Olohuone etu led"
canbus:
  - platform: esp32_can
    tx_pin: GPIO27
    rx_pin: GPIO26
    can_id: 100       # can id for transmitting frames
    bit_rate: 125kbps # talomat rate
    on_frame:
    - can_id: 0  # listen to all messages
      can_id_mask: 0
      use_extended_id: True
      then:
      - lambda: |-
          bool tunnistettu = false;
          int muunnos_temp;
          bool debug_on = false;
          // Ulkolämpötila
          if(x[0]==0x06 and x[1]==0x09 and x[2]==0x31) {
            if(x[3]>127) {
              muunnos_temp = x[3] - 256;
            else {
              muunnos_temp = x[3];
            id(temp_ulko).publish_state(muunnos_temp);
            tunnistettu = true;
          // Sisälämpötila
          if(x[0]==0x06 and x[1]==0x08 and x[2]==0x31) {
            if(x[3]>127) {
            else {
            id(temp_sisa).publish_state(muunnos_temp);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x32 and x[2]==0x27) {
            id(valo_ulko_raw).publish_state(x[3]);
            tunnistettu = true;
          // Liiketunnistin yläkerta
          if(x[0]==0x06 and x[1]==0x97 and x[2]==0x20) {
            id(liiketunnistin_ylakerta).publish_state(x[3]);
            tunnistettu = true;
          // Liiketunnistin kodinhoitohuone
          if(x[0]==0x06 and x[1]==0x94 and x[2]==0x20) {
            id(liiketunnistin_kodinhoitohuone).publish_state(x[3]);
            tunnistettu = true;
          // Liiketunnistin eteinen
          if(x[0]==0x06 and x[1]==0x93 and x[2]==0x20) {
            id(liiketunnistin_eteinen).publish_state(x[3]);
            tunnistettu = true;
          // Liiketunnistin etuterassi
          if(x[0]==0x06 and x[1]==0x91 and x[2]==0x20) {
            id(liiketunnistin_etuterassi).publish_state(x[3]);
            tunnistettu = true;
          // Liiketunnistin autokatos
          if(x[0]==0x06 and x[1]==0x95 and x[2]==0x20) {
            id(liiketunnistin_autokatos).publish_state(x[3]);
            tunnistettu = true;
          // Liiketunnistin takaterassi
          if(x[0]==0x06 and x[1]==0x92 and x[2]==0x20) {
            id(liiketunnistin_takaterassi).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x30 and x[2]==0x61) tunnistettu = true; // Työhuone katto LED
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x90 and x[2]==0x61) tunnistettu = true; // Työhuone katto Kansi
          if(x[0]==0x06 and x[1]==0x91 and x[2]==0x61) {
            id(tyohuone_kansi).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x00 and x[2]==0x64) tunnistettu = true; // Antonin huone katto Led
          if(x[0]==0x06 and x[1]==0x01 and x[2]==0x64) {
            id(antonhuone_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x30 and x[2]==0x64) tunnistettu = true; // Antonin huone katto Kansi
          if(x[0]==0x06 and x[1]==0x31 and x[2]==0x64) {
            id(antonhuone_kansi).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x80 and x[2]==0x64) tunnistettu = true; // Joonaksen huone katto Led
          if(x[0]==0x06 and x[1]==0x81 and x[2]==0x64) {
            id(joonashuone_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x50 and x[2]==0x64) tunnistettu = true; // Joonaksen huone katto Kansi
          if(x[0]==0x06 and x[1]==0x51 and x[2]==0x64) {
            id(joonashuone_kansi).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x80 and x[2]==0x62) tunnistettu = true; // Porras katto Kansi
          if(x[0]==0x06 and x[1]==0x81 and x[2]==0x62) {
            id(porras_kansi).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x50 and x[2]==0x62) tunnistettu = true; // Yläaula katto Led
          if(x[0]==0x06 and x[1]==0x51 and x[2]==0x62) {
            id(ylaaula_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0xa0 and x[2]==0x62) tunnistettu = true; // Yläkerta WC katto Led
          if(x[0]==0x06 and x[1]==0xa1 and x[2]==0x62) {
            id(ylavessa_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0xb0 and x[2]==0x63) tunnistettu = true; // Vaatehuone katto Led
          if(x[0]==0x06 and x[1]==0xb1 and x[2]==0x63) {
            id(vaatehuone_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x10 and x[2]==0x61) tunnistettu = true; // Alakerta Wc katto Led
          if(x[0]==0x06 and x[1]==0x11 and x[2]==0x61) {
            id(alavessa_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0xd0 and x[2]==0x64) tunnistettu = true; // Sauna seinä Kansi
          if(x[0]==0x06 and x[1]==0xd1 and x[2]==0x64) {
            id(sauna_kansi).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0xe0 and x[2]==0x64) tunnistettu = true; // Sauna katto Kuitu
          if(x[0]==0x06 and x[1]==0xe1 and x[2]==0x64) {
            id(sauna_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x60 and x[2]==0x60) tunnistettu = true; // Kylpyhuone katto LED
          if(x[0]==0x06 and x[1]==0x61 and x[2]==0x60) {
            id(kylpyhuone_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x40 and x[2]==0x60) tunnistettu = true; // Kodinhoitohuone katto Led
          if(x[0]==0x06 and x[1]==0x41 and x[2]==0x60) {
            id(kodinhoitohuone_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x10 and x[2]==0x64) tunnistettu = true; // Makuuhuone katto Kansi
          if(x[0]==0x06 and x[1]==0x11 and x[2]==0x64) {
            id(makuuhuone_kansi).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x50 and x[2]==0x63) tunnistettu = true; // Makuuhuone katto Led
          if(x[0]==0x06 and x[1]==0x51 and x[2]==0x63) {
            id(makuuhuone_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x30 and x[2]==0x20) tunnistettu = true; // Keittiö katto Kansi
          if(x[0]==0x06 and x[1]==0x31 and x[2]==0x20) {
            id(keittio_kansi).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x10 and x[2]==0x60) tunnistettu = true; // Keittiö katto Led
          if(x[0]==0x06 and x[1]==0x11 and x[2]==0x60) {
            id(keittio_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x80 and x[2]==0x61) tunnistettu = true; // Keittiö taso Lednauha
          if(x[0]==0x06 and x[1]==0x81 and x[2]==0x61) {
            id(keittioallas_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x70 and x[2]==0x61) tunnistettu = true; // Keittiö uuni Lednauha
          if(x[0]==0x06 and x[1]==0x71 and x[2]==0x61) {
            id(keittiouuni_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x90 and x[2]==0x60) tunnistettu = true; // Keittiö porrasaula katto Led
          if(x[0]==0x06 and x[1]==0x91 and x[2]==0x60) {
            id(keittioporras_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x60 and x[2]==0x62) tunnistettu = true; // Kodinhoitohuone allas Lednauha
          if(x[0]==0x06 and x[1]==0x61 and x[2]==0x62) {
            id(kodinhoitohuone_allas_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0xb0 and x[2]==0x62) tunnistettu = true; // Etuterassi seinä Kansi
          if(x[0]==0x06 and x[1]==0xb1 and x[2]==0x62) {
            id(etuterassi_seina).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x10 and x[2]==0x63) tunnistettu = true; // Etuterassi katto Led
          if(x[0]==0x06 and x[1]==0x11 and x[2]==0x63) {
            id(etuterassi_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x20 and x[2]==0x63) tunnistettu = true; // Autokatos seinä Kansi
          if(x[0]==0x06 and x[1]==0x21 and x[2]==0x63) {
            id(autokatos_seina).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x30 and x[2]==0x63) tunnistettu = true; // Autokatos katto Led
          if(x[0]==0x06 and x[1]==0x31 and x[2]==0x63) {
            id(autokatos_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0xd0 and x[2]==0x62) tunnistettu = true; // Etupiha Pylväs
          if(x[0]==0x06 and x[1]==0xd1 and x[2]==0x62) {
            id(etupiha_pylvas).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x70 and x[2]==0x65) tunnistettu = true; // Tekninen tila katto Kansi
          if(x[0]==0x06 and x[1]==0x71 and x[2]==0x65) {
            id(tekninen_kansi).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x10 and x[2]==0x65) tunnistettu = true; // Sisävarasto katto Kansi
          if(x[0]==0x06 and x[1]==0x11 and x[2]==0x65) {
            id(sisavarasto_kansi).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x30 and x[2]==0x62) tunnistettu = true; // Olohuone taka oikea katto Led
          if(x[0]==0x06 and x[1]==0x31 and x[2]==0x62) {
            id(ohtakaoikea_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x20 and x[2]==0x62) tunnistettu = true; // Olohuone taka vasen katto Led
          if(x[0]==0x06 and x[1]==0x21 and x[2]==0x62) {
            id(ohtakavasen_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x60 and x[2]==0x61) tunnistettu = true; // Olohuone takka katto Led
          if(x[0]==0x06 and x[1]==0x61 and x[2]==0x61) {
            id(ohtakka_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x30 and x[2]==0x60) tunnistettu = true; // Eteinen WC edusta katto Led
          if(x[0]==0x06 and x[1]==0x31 and x[2]==0x60) {
            id(eteinenwc_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x40 and x[2]==0x62) tunnistettu = true; // Eteinen vaatekaappi Lednauha
          if(x[0]==0x06 and x[1]==0x41 and x[2]==0x62) {
            id(eteinenvaatekaappi_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x50 and x[2]==0x60) tunnistettu = true; // Eteinen katto Led
          if(x[0]==0x06 and x[1]==0x51 and x[2]==0x60) {
            id(eteinen_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x20 and x[2]==0x60) tunnistettu = true; // Olohuone etu katto Led
          if(x[0]==0x06 and x[1]==0x21 and x[2]==0x60) {
            id(ohetu_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x00 and x[2]==0x63) tunnistettu = true; // Takaterassi katto Led
          if(x[0]==0x06 and x[1]==0x01 and x[2]==0x63) {
            id(takaterassi_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0xf0 and x[2]==0x62) tunnistettu = true; // Takaterassi seinä Kansi
          if(x[0]==0x06 and x[1]==0xf1 and x[2]==0x62) {
            id(takaterassi_seina).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0xe0 and x[2]==0x62) tunnistettu = true; // Takapiha Pylväs
          if(x[0]==0x06 and x[1]==0xe1 and x[2]==0x62) {
            id(takapiha_pylvas).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x90 and x[2]==0x62) tunnistettu = true; // Eteinen seinä Kansi
          if(x[0]==0x06 and x[1]==0x91 and x[2]==0x62) {
            id(eteinen_seina).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x60 and x[2]==0x65) tunnistettu = true; // Parveke katto Led
          if(x[0]==0x06 and x[1]==0x61 and x[2]==0x65) {
            id(parveke_led).publish_state(x[3]);
            tunnistettu = true;
          if(x[0]==0x06 and x[1]==0x50 and x[2]==0x65) tunnistettu = true; // Parveke seinä Kansi
          if(x[0]==0x06 and x[1]==0x51 and x[2]==0x65) {
            id(parveke_seina).publish_state(x[3]);
            tunnistettu = true;
          // DEBUG
          if (x[0] != 15 and x[0] != 10 and tunnistettu == false) {
            ESP_LOGD("can_id", "CAN ID %x : %x             : 0b%i%i%i%i %i%i%i%i 0b%i%i%i%i %i%i%i%i 0b%i%i%i%i %i%i%i%i 0b%i%i%i%i %i%i%i%i               Hex %02x %02x %02x %02x     Dec %3i %3i %3i %3i", can_id,  remote_transmission_request,
            (x[0] >> 7) &1, (x[0] >> 6) &1, (x[0] >> 5) &1, (x[0] >> 4) &1, (x[0] >> 3) &1, (x[0] >> 2) &1, (x[0] >> 1) &1, (x[0] >> 0) &1,
            (x[1] >> 7) &1, (x[1] >> 6) &1, (x[1] >> 5) &1, (x[1] >> 4) &1, (x[1] >> 3) &1, (x[1] >> 2) &1, (x[1] >> 1) &1, (x[1] >> 0) &1,
            (x[2] >> 7) &1, (x[2] >> 6) &1, (x[2] >> 5) &1, (x[2] >> 4) &1, (x[2] >> 3) &1, (x[2] >> 2) &1, (x[2] >> 1) &1, (x[2] >> 0) &1,
            (x[3] >> 7) &1, (x[3] >> 6) &1, (x[3] >> 5) &1, (x[3] >> 4) &1, (x[3] >> 3) &1, (x[3] >> 2) &1, (x[3] >> 1) &1, (x[3] >> 0) &1,
            x[0], x[1], x[2], x[3], x[0], x[1], x[2], x[3]);
          if (x[0] != 15 and x[0] != 10 and tunnistettu == true and debug_on == true) {
            ESP_LOGD("can_id", "CAN ID %x : %x tunnistettu : 0b%i%i%i%i %i%i%i%i 0b%i%i%i%i %i%i%i%i 0b%i%i%i%i %i%i%i%i 0b%i%i%i%i %i%i%i%i               Hex %02x %02x %02x %02x     Dec %3i %3i %3i %3i", can_id,  remote_transmission_request,
           if (x[0] == 10 and tunnistettu == false) {
            ESP_LOGD("can_id", "CAN ID %x : %x             : 0b%i%i%i%i %i%i%i%i 0b%i%i%i%i %i%i%i%i 0b%i%i%i%i %i%i%i%i 0b%i%i%i%i %i%i%i%i 0b%i%i%i%i %i%i%i%i   Hex %02x %02x %02x %02x %02x  Dec %3i %3i %3i %3i %3i", can_id,  remote_transmission_request,
            (x[4] >> 7) &1, (x[4] >> 6) &1, (x[4] >> 5) &1, (x[4] >> 4) &1, (x[4] >> 3) &1, (x[4] >> 2) &1, (x[4] >> 1) &1, (x[4] >> 0) &1,
            x[0], x[1], x[2], x[3], x[4], x[0], x[1], x[2], x[3], x[4]);
          if (x[0] == 15 and tunnistettu == false) {
