Hi, I have 2 IKEA LED1836G9 and I need to sync brightness of them. I made an automation, where I can react to brightness change of 1st bulb, but how could I read this value and write this value to 2nd one?
Many thanks for help.
Use a State Trigger to monitor the lightâs brightness attribute and, in its action, sets the other lightâs brightness attribute to the same value (using the light.turn_on service)
Alternately, you could use a Light Group which creates a separate (virtual) light entity that controls the two IKEA lights. Set this virtual light entityâs brightness and the other two lights will be automatically set to the same brightness.
I know the theory - but how can I set brightness to 2nd bulb? And how can I set the same brightness (where I can read brightness of 1st one)?
alias: Sync
description: ''
- platform: state
entity_id: light.zarovka1
attribute: brightness
condition: []
- condition: state
entity_id: light.zarovka2
state: '100'
mode: single
Action on change brightness on Zarovka2 happens, but this brightness set does nothing.
(Light group works and itâs ideal, but question is still the same).
Also, for my light group âStropni svetloâ this script does nothing:
alias: New Script
sequence:
- condition: state
entity_id: light.stropni_svetlo
state: '100'
mode: single
Thatâs because itâs not âsettingâ anything. You have put a condition into the action which only serves as a filter. It is checking if zarovkaâs brightness is 100. If it is or it isnât wonât make a difference because you have not supplied anything after the condition. You did the same thing in the script so thatâs why it doesnât âdoâ anything either.
Remove the needless condition and replace it with a service call to light.turn_on (like I had suggested previously).
Itâll be something like this (sorry but I donât have time to test it).
alias: Sync
description: ''
- platform: state
condition: []
- service: light.turn_on
brightness: "{{ trigger.to_state.attributes.brightness }}"
mode: single
Now we are going somewhere. That works for static settings. But what if I want to use state of a different entity as variable:
alias: Brightness_sync
sequence:
brightness: state_attr('light.zarovka1', 'brightness'))
mode: single
Returns that it expected int.
I havenât been YAMLing for long but give this a shot, it might work. Dunno what that âmodeâ thing is, it wasnât there the last time I coded
sequence:
data_template:
brightness: "{{state_attr('light.zarovka1', 'brightness')|int}}"
mode: single
That works, thanks, even itâs not needed to reconvert data into int.
Itâs good practice to avoid errors :). Iâm glad it helped
I donât think you understand the purpose of the Solution tag. Iâve watched you assign it to several posts as you appear to change your mind about which one solves the original problem.
The latest one you marked as the Solution doesnât answer the original question, it answers a separate question (for a script implementation vs an automation). That means users reading the original problem are led to a Solution that solves a different one.
Honestly, I donât know what you mean by a âstatic settingâ. The example I posted takes the current brightness of zarovka1 (via the Trigger State Object) and assigns it to zarovka2. Thatâs what your first post requested:
made an automation, where I can react to brightness change of 1st bulb, how could I read this value and write this value to 2nd one?
The reason why this failed to work for you (in the script) is because itâs not a template:
Taras: Thatâs because it SOLVES that problem - it ANSWERS my question.
Static - means that you set a STATIC value, not variable (being readen from another entity).
I think what you may have overlooked is that this service call in the automation:
is functionally equivalent to this service call in the script:
brightness: "{{ state_attr('light.zarovka1', 'brightness')) }}"
The reason why itâs equivalent is because the automation is triggered by zarovka1âs brightness changes which are represented by the Trigger State Object in the template:
The only real difference between the automation and the script is:
Your first and second posts concerned an automation. In your third post you changed direction and posted a script (which contained an invalid template). Obaldius corrected the invalid template.
Now you have two ways to achieve the goal of synchronizing the lights:
Even more complex solution, many thanks
I have spotlights controlled by a Shelly dimmer and want a zigbee bulb to turn ON/OFF and also follow the brightness off the Shelly.
Struggled a bit and then found this topic. Got it working, I make this reply to say thanks and also hopefully help someone with the below automation example.
alias: Korskoppling brightness, spottar-prydnadslampa
description: ""
- platform: state
entity_id:
- light.dimmer_gillestugan
to: "off"
- platform: state
entity_id:
id: Turn ON or change Brightness
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
entity_id: light.prydnadslampa_gillestugan
alias: Turn on or change brightness to same as spottar
- conditions:
sequence:
- service: light.turn_off
data: {}
mode: single
How to add the color temperature synchronization of the light? Or can you write a blueprint format?
