I am trying to set-up an automation to automatically turn my lights on when my sensors are seeing movement. Sone lights are not very bright and are probably turned on with 1% brightess. I’ve got it done using the yaml script down shown down below in my automations.yaml file. Unfortunately it tells me there is an error.
Logger: homeassistant.config
Source: config.py:416
First occurred: 4:09:03 AM (3 occurrences)
Last logged: 4:09:03 AM
Invalid config for [automation]: [data] is an invalid option for [automation]. Check: automation->data. (See /config/configuration.yaml, line 13).
Invalid config for [automation]: Entity ID all is an invalid entity id for dictionary value @ data[‘condition’][0][‘entity_id’]. Got None. (See /config/configuration.yaml, line 13).
Could someone tell me why this is getting an error?
Best regards,
# Automatisering Hal
- alias: Hal lamp aan bij beweging
platform: state
entity_id: binary_sensor.hue_motion_sensor_hal_motion
to: "on"
service: light.turn_on
entity_id: light.hue_hal_lamp
brightness_pct: 100
- alias: Hal lamp uit bij geen beweging voor 5 minuten
platform: state
to: "off"
for:
minutes: 5
service: light.turn_off
platform: state
to: "on"
brightness_pct: 100
Thank you for your first reply. I’ve changed the configuration file to what you’ve said, but it seems that it still tells me the same error:
First occurred: 4:30:09 AM (2 occurrences)
Last logged: 4:30:09 AM
Down below is my full configuration of my first automation. It turns on the lights when the sensor sees something. It turns of the lights after not seeing anything for 5 minutes.
platform: state
to: "on"
brightness_pct: 100
platform: state
to: "off"
for:
minutes: 5
I’m sorry all, I feel so stupid.
I used an automation using a condition to turn on the lights when the sun is going down. I thought the error mentioned line 13 somewhere so I got confused. Thanks for helping me out everyone.
