Home Assistant n00b here. I setup Home Assistant and connected to my Centralite Pearl thermostat I just installed via Conbee II. I’m able to see the current temp and set the target via the dashboard, but when I go to create an automation to change the target at a specific time, my only option is to change the mode (Heat, Cool).
here’s what I’m seeing:
Is it not possible to create an action that changes the target temp using ZHA? Should I be using Zigbee2Mqtt instead?
Thanks!
