I want to setup a number as a helper to input a desired room temperature so I can control my central heating system. When I want to configure the helper from the UI I miss fields like Initial, step and mode.
I especially need the step value, because I need to be able to set the temperature with 1 decimal precision. (e.g. 22.3) How can I do that?
Do I need to add it manually to the configuration.yaml, or is there a more easy way?
Thanks!
