Setting Modbus swith
Hey i am having some issues with setting switch
I am using
https://www.ebay.com/itm/8CH-12V-Modbus-RTU-RS485-Relay-Module-Switch-Board-for-PLC-Lamp-LED-PTZ-Camera/232157573674?epid=2085409210&hash=item360dab722a:g:SBoAAOSwux5YO-tX
and trying to use it with https://www.ebay.com/itm/New-USB-to-RS485-USB-485-Converter-Adapter-Support-Win7-XP-Vista-Linux-Mac-OS/201414902344?epid=927930972&hash=item2ee5438248:g:pQAAAOSwQiRUl4gB
adapter ,
i saw there are some issues with the driver , and maybe this is the only issue,
but i could understand the difference between switch to register …
and could not link both devices…
any particular solution that may work?
Hello Porainir,
I’m a new enthusiast user at home assistant.
I bought a card as well as the one you put in the picture, modbus.
I did some tests but I was not able to use it with home assistant.
Did you do it?
Could you help me?
Thank you very much
Hey need some more information ,
which converter are you using ?
how do you connect the converter to the pi?
which HA version you are using?
Thanks for the reply
The version of home assistant is: Home Assistant 0.84.3 with HassOS 1.13
For the other questions I have attached a photo.
Hey the problem , is subjected to the adapter you need special driver, i suggest to change the adapter.
